Internet Routing using MPLS Aggregate Lookup
I'm attempting to adapt a scenario from the MPLS and VPN Architecture CCIP edition book.  The scenario that I'm working with has two PE/P IOS XR routers in a collapsed MPLS core.  All customers are terminated in their own VRF on each PE/P router.  I want to be able to terminate multiple Internet providers on the PE/P routers as a cost-cutting measure and the question I'm trying to solve is how to route the customer traffic to the Internet.
Page 233 of the MPLS and VPN Architecture CCIP edition book lays out the possibility of using default route that generates an aggregate label thus forcing the PE to perform a lookup in the Internet VRF prior to forwarding the packet.  I've set up this scenario in a lab whereby the Internet VRF on the left PE/P router has a static default configured pointing at a loopback address in the VRF.  The Left PE/P progagates the default through MPBGP using the network 0.0.0.0 command.  All customer VRFs that require internet access receive the default.  When customer traffic on the right PE/P is forwarded to the Internet VRF by the default, forwarding works - the aggregate lable forces a lookup to be performed in the Internet VRF where full Internet routes exist and the packet is forwarded using the best path.  The problem is that customer traffic using the default route from the left PE/P router is blackholed.  The aggregate lookup doesn't work and the customers terminated on the left PE/P do not have Internet access.  The scenario in the book is using a third router attached to each PE to distribute the aggregate default route. Is it possible to make it work without requiring a third device to propagate the MPLS aggregate labelled default route?
The basic configs are below:
Right PE:
vrf VRF_TEST
address-family ipv4 unicast
  import route-target
   555:5555123
   555:5555555
  export route-target
   555:5555555
router bgp 65005
vrf VRF_TEST
  rd 555:5555555
   redistribute connected
RP/0/RSP0/CPU0:RouterRight#sho route vrf VRF_TEST
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
B*   0.0.0.0/0 [200/0] via 192.168.1.1 (nexthop in vrf default), 00:00:29
L    192.168.202.1/32 is directly connected, 18:01:24, Loopback5555
Left PE:
vrf VRF_INET_TEST
  import route-target
   555:5555555
  export route-target
   555:5555123
vrf VRF_TEST
  import route-target
   555:5555123
   555:5555555
  export route-target
   555:5555555
router bgp 65005
vrf VRF_INET_TEST
  rd 555:5555123
   network 0.0.0.0/0
router bgp 65005
vrf VRF_TEST
  rd 555:5555555
router static
vrf VRF_INET_TEST
   0.0.0.0/0 Loopback5555
interface Loopback5555
vrf VRF_INET_TEST
ipv4 address 192.168.200.1 255.255.255.255
RP/0/RSP0/CPU0:RouterLeft#sho route vrf VRF_TEST
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
B*   0.0.0.0/0 is directly connected, 00:03:09, Loopback5555 (nexthop in vrf VRF_INET_TEST)
B    192.168.200.1/32 is directly connected, 17:34:46, Loopback5555 (nexthop in vrf VRF_INET_TEST)
L    192.168.201.1/32 is directly connected, 18:07:59, Loopback12345
RP/0/RSP0/CPU0:RouterLeft#sho route vrf VRF_INET_TEST
S*   0.0.0.0/0 is directly connected, 00:03:25, Loopback5555
L    192.168.200.1/32 is directly connected, 18:13:17, Loopback5555
B    192.168.201.1/32 is directly connected, 17:35:02, Loopback12345 (nexthop in vrf VRF_TEST)
B    192.168.202.1/32 [200/0] via 192.168.1.2 (nexthop in vrf default), 18:04:21
B     <Full Table of Internet Routes - Snipped>
shivjain
hi
aggregate label is generated only by the router which is the exit interface of vrf. aggregate label means remove all the label and perform the ip lookup.
it all depends how would you like to proceed.
Use of aggregate labels
http://www.mplsvpn.info/2009/02/use-of-aggregate-labels.html
how internet works in vrf by using aggregate label
http://www.mplsvpn.info/2009/03/provisioning-internet-with-internet-vrf.html
regards
shivlu jain
I've seen those links before but the scenario isn't quite the same as what I am trying to do.  In the "how internet works in vrf by using aggregate label" article, combine the function of R2 and R1 so the Internet gateway and the PE device are the same.  I understand how your scenario plays out when the Internet gateway is one device removed, that matches the scenario laid out in the MPLS and VPN Architectures book in my original question.  What I am trying to do is combine the Internet Gateway and PE functionality into one device... For example:
ISP_A ------------ R1 (PE/IGW) ----------- CPE
