MPLS - Bytes Switched is Zero
Hi eveyone,
To try to explain the scenario, we have a solution with Inter-AS Option C.
In ASBR when we run the following command:
RP/0/RSP0/CPU0:Router#show mpls forwarding labels 16350
Mon Jul 23 16:53:11.282 WEST
Local  Outgoing    Prefix                Outgoing        Next Hop        Bytes
Label  Label            or ID                Interface                             Switched
16350  16103       1.1.1.1/32           Te0/0/0/0.2   10.10.10.1     0
The number of bytes switched is zero. This is normal?
And we don't have any problem with this prefix ...
Thanks a lot
0 Replies 0
