Bookmark
Subscribe
1246
Interworking on Static Routing as IGP
attrgautam
Level 5
Level 5
Was testing interworking between Vlan over ethernet and FR. As long as my LDP was on static routing, I couldnt reach end-to-end. The moment i configured OSPF as my routing protocol it came up. Can anyone let me know what the reason could be ?
Gautam,
This is actually normal behavior.
Before the label learnt via an LDP peer is coupled to a route in the FIB, the next-hop IP address of the route needs to match one of the interface IP addresses bound to the LDP peer (see below). So basically it will not work without a next IP address.
r2#sh mpls ldp nei
Peer LDP Ident: 3.3.3.3:0; Local LDP Ident 2.2.2.2:0
TCP connection: 3.3.3.3.11004 - 2.2.2.2.646
State: Oper; Msgs sent/rcvd: 27/27; Downstream
Up time: 00:15:07
LDP discovery sources:
Serial3/0, Src IP addr: 192.168.23.3
Addresses bound to peer LDP Ident:
3.3.3.3 192.168.34.3 192.168.23.3 <++++++ the route next hop has to match one of these addresses.
Hope this helps,
5 Replies 5
Harold Ritter
It should work with static routes as well as with dynamic routing protocols.
Make sure that you have connectivity between the loopback addresses of the two PEs and between loopback addresses of each LDP (or TDP) neighbors.
Let me know if I answered your question,
The issue was with non recursive routing in my P router. I added non recursive routes and it was fine. Suprised this issue isnt solved even in 12.0(28)s
Can you elaborate on what you recursive routes were?
for my remote loopback, there were static routes in my P router
For eg
Initial Config
ip route x.x.x.x 255.255.255.255 S0/0
Working config
ip route x.x.x.x 255.255.255.255 S0/0 192.168.1.2
Gautam,
r2#sh mpls ldp nei
Up time: 00:15:07
Hope this helps,
