IOS XR VRF LITE Leaking
uni1389
Am trying to use VRF-Lite Route leaking , but am able to import/export routes between two vrfs.  Ping is working within VRF to/from hosts , but am not able ping between two nodes.(Server/Host). Configuration/toplogy is mentioned below for feedback.
RP/0/RP0/CPU0:ASR9K#show running-config vrf
vrf BLUE
rd 172:16
address-family ipv4 unicast
import route-target
168:11
172:16
export route-target
168:11
172:16
vrf WHITE
rd 168:11
import route-target
168:11
172:16
export route-target
168:11
172:16
RP/0/RP0/CPU0:ASR9K#show run interface gigabitEthernet 0/0/0/0
interface GigabitEthernet0/0/0/0
cdp
vrf BLUE
ipv4 address 172.16.20.1 255.255.255.0
RP/0/RP0/CPU0:ASR9K#show run interface gigabitEthernet 0/0/0/1
interface GigabitEthernet0/0/0/1
cdp
vrf WHITE
ipv4 address 192.168.11.1 255.255.255.0
RP/0/RP0/CPU0:ASR9K#ping vrf BLUE 172.16.20.1
Sending 5, 100-byte ICMP Echos to 172.16.20.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
RP/0/RP0/CPU0:ASR9K#ping vrf BLUE 172.16.20.100
Sending 5, 100-byte ICMP Echos to 172.16.20.100, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 33/41/45 ms
RP/0/RP0/CPU0:ASR9K#show route vrf ALL
VRF: BLUE
Codes: C - connected, S - static, R - RIP, B - BGP, (>) - Diversion path
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - ISIS, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, su - IS-IS summary null, * - candidate default
U - per-user static route, o - ODR, L - local, G - DAGR, l - LISP
A - access/subscriber, a - Application route
M - mobile route, r - RPL, t - Traffic Engineering, (!) - FRR Backup path
Gateway of last resort is not set
C 172.16.20.0/24 is directly connected, 06:24:07, GigabitEthernet0/0/0/0
L 172.16.20.1/32 is directly connected, 06:24:07, GigabitEthernet0/0/0/0
VRF: WHITE
C 192.168.11.0/24 is directly connected, 05:41:26, GigabitEthernet0/0/0/1
L 192.168.11.1/32 is directly connected, 05:41:26, GigabitEthernet0/0/0/1
Harold Ritter
Hi @uni1389 ,
You need to configure BGP for the import/export to work. Here's a simple configuration of how it should be configured:
router bgp 111
address-family vpnv4 unicast
vrf WHITE
redistribute connected
vrf BLUE
Thanks Harold,
can we do it without BGP instance, like with static route.
Hi @uni1389 ,
Yes, it is certainly possible to use static routes to achieve the same:
router static
vrf BLUE
192.168.11.0/24 vrf WHITE GigabitEthernet0/0/0/1
vrf WHITE
172.16.20.0/24 vrf BLUE GigabitEthernet0/0/0/0
