IP_SLA_Load_Calculation_on_7600 !
Vaibhava Varma
Level 4
Level 4
Dear All
How do I calculate the expected increase in CPU Load and Memory Consumption with ~150 ICMP Echo IP SLA Operations running simultaneously with 1 Sec Frequency.
Varma
Adam Vitkovsky
Level 3
Level 3
Dear Varma,
I’m pretty sure the ICMP is handled by the line-card’s CPU so the performance is based on the type of the line-card.
You can as well use the “start-time random” so there’s no huge influx of SLA operations at once
adam
adam
