IP unnumbered + ISIS + BGP + MPLS
Rob85
Hi all,
I'm troubleshooting a setup between two routers R1 and R2. Both are using ip unnumbered with ISIS to distribute their loopback address.
BGP and MPLS are configured to distribute their connected loopback and subinterface into VRF quarantaine.
I see that the routes are installed in the VRF table, but they're not pingable.
Suggestions?
hostname R1
ip vrf quarantaine rd 65000:250 route-target export 65000:250 route-target import 65000:250!interface Loopback0 no shutdown ip address 10.0.1.1 255.255.255.255 ip router isis !interface Loopback250 no shutdown ip vrf forwarding quarantaine ip address 1.1.1.1 255.255.255.255!interface GigabitEthernet1 no shutdown ip unnumbered Loopback0 ip router isis  negotiation auto medium p2p mpls ip no mop enabled no mop sysid!interface GigabitEthernet8 no shutdown no ip address negotiation auto no mop enabled no mop sysid
!interface GigabitEthernet8.250 no shutdown encapsulation dot1Q 250 native ip vrf forwarding quarantaine
 ip address 10.101.250.1 255.255.255.0
!router isis net 49.0001.0000.0000.0008.00 metric-style narrow mpls ldp sync!router bgp 65000 ! bgp router-id interface Loopback0 bgp log-neighbor-changes no bgp default ipv4-unicast neighbor 10.0.1.2 remote-as 65000 neighbor 10.0.1.2 update-source Loopback0 ! address-family vpnv4  neighbor 10.0.1.2 activate  neighbor 10.0.1.2 send-community extended exit-address-family ! address-family ipv4 vrf quarantaine  redistribute connected exit-address-family
R2:
hostname R2!ip vrf quarantaine rd 65000:250 route-target export 65000:250 route-target import 65000:250!interface Loopback0 no shutdown ip address 10.0.1.2 255.255.255.255 ip router isis !interface Loopback250 no shutdown ip vrf forwarding quarantaine ip address 2.2.2.2 255.255.255.255!interface GigabitEthernet1 no shutdown ip unnumbered Loopback0 ip router isis  negotiation auto medium p2p mpls ip no mop enabled no mop sysid!interface GigabitEthernet8 no shutdown no ip address negotiation auto no mop enabled no mop sysid!interface GigabitEthernet8.250 no shutdown encapsulation dot1Q 250 native ip vrf forwarding quarantaine ip address 10.102.250.1 255.255.255.0!router isis net 49.0001.0000.0000.0010.00 metric-style narrow mpls ldp sync!router bgp 65000 bgp router-id interface Loopback0 bgp log-neighbor-changes no bgp default ipv4-unicast neighbor 10.0.1.1 remote-as 65000 neighbor 10.0.1.1 update-source Loopback0 ! address-family vpnv4  neighbor 10.0.1.1 activate  neighbor 10.0.1.1 send-community extended exit-address-family ! address-family ipv4 vrf quarantaine  redistribute connected exit-address-family
Harold Ritter
Hi @Rob85 ,
Just remove the "medium p2p" from GI1 on both sides. It should fix it.
 no shutdown
 ip unnumbered Loopback0<<- use IP instead of unnumbered Loopback, note that delete remove LOOPBACK0 or change the config of BGP are config are right except this point.
 ip router isis
 negotiation auto
 medium p2p
 mpls ip
 no mop enabled
 no mop sysid
Harold Ritter
Hi @Rob85 ,
You're correct. Good catch.. it slipt into my "getting ISIS with ip unnumbered to work" config snip.
With this setup you can connect all sort of routers in various topologies. Now I need to tweak on the BGP settings, but the general contruct is working now. Thanks!
