07-07-2022 01:17 AM
Hello All,
I have following set up. I have created an ebgp-VPLS session between CSR1 and CSR3. But ping between CSR16 and CSR17 is not working.
CSR16-----CSR1---------CSR2----------CSR3--------CSR17
Following is the configuration.
csr16
int gi1
no sh
int gi1.30
encap dot1q 30
ip address 100.10.10.16 255.255.255.0
no sh
CSR1
int gi2
ip address 100.10.20.1 255.255.255.0
ip ospf 1 area 0
no sh
int lo0
ip address 1.1.1.1 255.255.255.255
ip ospf 1 area 0
exit
router ospf 1
mpls ldp autoconfig
exit
int gi1
service instance 100 ethernet
encap dot1q 30
exit
no sh
l2vpn vfi context ctx1
vpn id 123
autodiscovery bgp signaling bgp
ve id 1
exit
bridge-domain 100
member gig1 service-instance 100
member vfi ctx1
exit
router bgp 1
neighbor 3.3.3.3 remote-as 3
neighbor 3.3.3.3 update-source lo0
neighbor 3.3.3.3 ebgp-multihop
address-family l2vpn vpls
neighbor 3.3.3.3 activate
neighbor 3.3.3.3 suppress ldp
exit
CSR2
int gi2
ip address 100.10.20.2 255.255.255.0
ip ospf 1 area 0
no sh
int gi1
ip address 100.20.30.2 255.255.255.0
ip ospf 1 area 0
no sh
int lo0
ip address 2.2.2.2 255.255.255.255
ip ospf 1 area 0
exit
router ospf 1
mpls ldp autoconfig
CSR3
int gi1
ip ospf 1 area 0
ip address 100.20.30.3 255.255.255.0
no sh
int gi2
encap dot1q 30
exit
no sh
int lo0
ip ospf 1 area 0
ip address 3.3.3.3 255.255.255.255
exit
router ospf 1
mpls ldp autoconfig
exit
vpn id 123
ve id 3
exit
bridge-domain 100
member gig2 service-instance 100
member vfi ctx1
exit
l2vpn
router-id 3.3.3.3
exit
router bgp 3
neighbor 1.1.1.1 remote-as 1
neighbor 1.1.1.1 update-source lo0
neighbor 1.1.1.1 ebgp-multihop
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 suppress ldp
exit
csr17
int gi2
no sh
int gi2.30
encap dot1q 30
ip address 100.10.10.17 255.255.255.0
no sh
Sachin
Solved! Go to Solution.
07-07-2022 10:46 AM
Hi @sachin30720041 ,
I noticed the ebgp configuration after I replied. You should definitely use ibgp for VPLS deployment.
07-07-2022 08:36 AM - edited 07-07-2022 09:54 AM
The CSR1000v requires a different way to configure the dot1q subinterfaces.
Please refer to the following post for more details on the way to configure it.
https://community.cisco.com/t5/mpls/configuring-bgp-evpn-with-cisco-csr/td-p/4469809
07-07-2022 10:06 AM
Hi Harold,
If I use the same config but change ebp-vpls session to ibgp-vpls session then ping works. Can we not use ebgp-VPLS session for VPLS configuration ?
Sachin
07-07-2022 10:46 AM
07-07-2022 03:15 PM
next-hop-unchanged <- try add this eBGP neighbor Discover and save your favorite ideas. Come back to expert answers, step-by-step guides, recent topics, and more.
