%IPRT-3-RIB_LOOP: Resolution loop formed by routes in RIB
CSCO11777723
Does someone know how to debug this error message please?
This error message spread everywhere inside my network.
thanks!!
6 Replies 6
Mohammed Imran Khan
Hello Vincent,
This error mean that RIB route producers have installed routes in the RIB that form a loop during resolution. But, there could be several reasons for this. For. eg: a route received from a neighboring device and being installed in the RIB that conflicted with an already known/installed path.
When were these logs observed? Are there any other logs alongside this which can shed some more light on the actual problem. The supporting logs can tell which component is triggering this (like CEF discovering the routing for a prefix has recursive paths that lead back to itself). These logs are merely symptoms.
"show log" and "show ip route loops" will be good to have to start with!
Imran
Spot on chang, I just got this in a lab and that was the solution :)
ciscochang
Could be a problem that the subnet of the point-to-point interface does not match.
i.e. a /24 on one side and a /30 on the other.
Just experienced a similar problem.
Really spot on . Just faced an similar issues and got it resolved. subnets were mismatched. Thanks.
Experienced the same isssue,  invalid p2p subnet mask.
I had this problem when I make iBGP configuration without update-source/next-hop-self,
there was very complex topology so I can't explain exactly reason. shortly there really was loop.
sh ip route loops
sh ip bgp rib-failure
