IRB with EomPLS
lee.reade
Level 8
Level 8
I have a requirement to do IRB alongside EoMPLS, and am looking for some guidance if it is indeed possible.
The setup is as follows;
CISCO3925 with all host connections on the onboard EHWIC-D-8ESG-P with 152-4.M1.
VLAN 2000 ----- ETHPORT1 --- EoMPLS -- CORE--SVI DEFAULT GW
              IRB    |
VLAN 2001 ----- ETHPORT2
The EoMPLS part is staight forward, this works fine, so the client uses the default gw at the core headend where the EoMPLS terminates. I require the new vlan to also be part of the same routed network as VLAN 2000.
However I am not sure if the IRB would work, since it relies on the BVI for routing into/out the bridge domain?
Anyone care to offer any advice?
LR
0 Replies 0
