L2tunnel Session remote id 0
RAMACHANDRA R
i could able to see the L2tun sessions are going down and not forming back and in the l2tun sessions state iam getting remote ID as 0 what could be the problem, i have attached the sho l2tun session out put also.
LocID RemID TunID Username, Intf/ State Last Chg Uniq ID
Vcid, Circuit
38467 0 57614 101, Gi0/2.101:101 wt-cc 00:00:01 11
Rama
gmarogi
Level 5
Level 5
The L2TP class configuration procedure creates a template of L2TP control channel parameters that can be inherited by different pseudowire classes. L2TP control channel parameters are used in control channel authentication, keepalive messages, and control channel negotiation. In an L2TPv3 session, the same L2TP class must be specified in the pseudowire configured on the PE router at each end of the control channel. Configuring L2TP control channel parameters is optional
shivlu jain
Level 5
Level 5
rama
Creation of tunnel id 0 is the problem of memory. You will be having chunk of 10 mb when it approaches to 6 - 7mb your tunnels got down.
regards
shivlu
