LabNetwork problems
rmv72
Level 7
Level 7
i've LabNetwork: MPLS cloud (PE1 and PE2 routers) and customers routers MSK1,SAM1,MSK_GW.
Routers MSK1 and SAM1 also connected between each other.
I want emulate failure link between customer router MSK1 and provider's PE1.
After it i want that router MSK_GW will be available for PE1 and PE2 via link between MSK1 and SAM1.
But it's not happened.
I can't understand where is my fault?
The issue is that you omitted to configured "ip vrf forwarding green" on fe0/0 on PE2, hence there is no ospf neighbor relationship between PE2 and SAM1 and therefore no redundancy.
Hope this helps,
rmv72
Level 7
Level 7
Here configs
Hope this helps,
Exactly!
Thank you!
