LDP connection between Cisco and Tellabs
mel_bs
I am working with an InterOps between Cisco12410 and Tellabs8800. The two boxes were connected directly using its GigabitEthernet ports.
I was able to define the MPLS LDP on the Cisco and Tellabs (cisco is in ldp discovery mode), however the neighborship between the two boxes cannot establish connection. When I used the "targeted" mode the status went active but LFIB shows "untagged" on the Tellabs IP address. The Cisco display is shown below
Is there something else I need to configure over the Cisco to make the LDP establish connection to Tellabs. Or does anybody knows what to work over the Tellabs?
GSR#sh mpls inter
Interface IP Tunnel Operational
GigabitEthernet2/2 Yes (ldp) No Yes
GigabitEthernet2/3 Yes (ldp) No Yes
GSR#sh ip ospf neigh
Neighbor ID Pri State Dead Time Address Interface
10.220.4.25 1 FULL/DR 00:00:38 10.254.10.2 GigabitEthernet2/2
172.27.2.1 1 FULL/BDR 00:00:37 10.254.1.2 GigabitEthernet2/3
GSR#sh mpls ldp discovery
Local LDP Identifier:
1.1.1.1:0
Discovery Sources:
Interfaces:
GigabitEthernet2/2 (ldp): xmit/recv
LDP Id: 2.2.2.2:0
GigabitEthernet2/3 (ldp): xmit
Targeted Hellos:
1.1.1.1 -> 172.27.2.1 (ldp): active, xmit/recv
LDP Id: 172.27.2.1:0
GSR#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR
Gateway of last resort is not set
1.0.0.0/32 is subnetted, 1 subnets
C 1.1.1.1 is directly connected, Loopback0
2.0.0.0/32 is subnetted, 1 subnets
O 2.2.2.2 [110/2] via 10.254.10.2, 01:05:36, GigabitEthernet2/2
172.27.0.0/32 is subnetted, 1 subnets
O E2 172.27.2.1 [110/0] via 10.254.1.2, 01:05:36, GigabitEthernet2/3
10.0.0.0/30 is subnetted, 2 subnets
C 10.254.1.0 is directly connected, GigabitEthernet2/3
C 10.254.10.0 is directly connected, GigabitEthernet2/2
GSR#sh mpls forwarding-table
Local Outgoing Prefix Bytes tag Outgoing Next Hop
tag tag or VC or Tunnel Id switched interface
16 Untagged 172.27.2.1/32 0 Gi2/3 10.254.1.2
18 0 2.2.2.2/32 0 Gi2/2 10.254.10.2
Mel Sebastian
mheusing
Hi Mel,
the output means that there are no LDP hellos received on GigabitEthernet2/3.
So you have to check the Tellabs device, why it does not send hellos on the interface.
The targeted LDP session is good news, as it shows basic interoperability.
Can you also post "show mpls ldp neighbor 172.27.2.1"? It would be good to check the tellabs box, if the GigE to the GSR is MPLS enabled.
Regards, Martin
mel_bs
I have below the "show mpls ldp neighbor" command which you requested. The Tellabs ip address is 172.27.2.1
GSR#sh mpls ldp neigh
Peer LDP Ident: 172.27.2.1:0; Local LDP Ident 1.1.1.1:0
TCP connection: 172.27.2.1.1027 - 1.1.1.1.646
State: Oper; Msgs sent/rcvd: 482/418; Downstream
Up time: 02:18:59
LDP discovery sources:
Targeted Hello 1.1.1.1 -> 172.27.2.1, active
Addresses bound to peer LDP Ident:
10.254.1.2 172.27.2.1
Peer LDP Ident: 2.2.2.2:0; Local LDP Ident 1.1.1.1:0
TCP connection: 2.2.2.2.21799 - 1.1.1.1.646
State: Oper; Msgs sent/rcvd: 156/154; Downstream
Up time: 02:09:44
GigabitEthernet2/2, Src IP addr: 10.254.10.2
Targeted Hello 1.1.1.1 -> 2.2.2.2, active, passive
2.2.2.2 10.254.10.2
Note: Tellabs is connected to Gi2/3. Cisco7609 is connected to Gi2/2. You might notice the neighborship status over the Gi2/2, config was changed having targeted connection over the GSR. Please focus only on Gi2/3 connection to Tellabs.
GSR#sh mpls ldp dis
1.1.1.1:0
Discovery Sources:
Interfaces:
LDP Id: 2.2.2.2:0
Targeted Hellos:
1.1.1.1 -> 2.2.2.2 (ldp): active/passive, xmit/recv
LDP Id: 2.2.2.2:0
Mel Sebastian
The information on GSR side all look OK, as Martin suggested, you need to check Tellabs side configuration to see why the interface which connects to GSR's gi2/3 is not sending LDP link hellos. I am sure Tellabs TMOS has something similar to IOS's sh mpls ldp neighbor and sh mpls ldp discover etch
