LDP - URGENT
ciscobuddy
Hi ALL,
Please help me for following issues. i hv mpls network and my P router that is GSR LDP was getting up and down. can any):
body tell me the why LDP was down.
following is the log file for P router.
Jan 19 15:06:23: %GRPGE-6-LINE_STATE: Interface GigabitEthernet2/0: Line state OK
Jan 19 15:06:25: %LINK-3-UPDOWN: Interface GigabitEthernet2/0, changed state to up
Jan 19 15:06:26: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0, changed state to up
Jan 19 15:06:34: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is UP
Jan 19 15:07:10: %OSPF-5-ADJCHG: Process 10, Nbr 202.183.64.5 on GigabitEthernet2/0 from LOADING to FULL, Loading Done
Feb 5 17:38:03: %GRPGE-6-SYNC_LOSS: Interface GigabitEthernet2/0: Loss of Sync
Feb 5 17:38:03: %GRPGE-6-RX_LOS: Interface GigabitEthernet2/0: Detected RX Loss of Signal
Feb 5 17:38:04: %GRPGE-6-GBIC_TX_FAULT: Interface GigabitEthernet2/0: GBIC TX Fault OK
Feb 5 17:38:05: %LINK-3-UPDOWN: Interface GigabitEthernet2/0, changed state to down
Feb 5 17:38:05: %OSPF-5-ADJCHG: Process 10, Nbr 202.183.64.5 on GigabitEthernet2/0 from 2WAY to DOWN, Neighbor Down: Interface down or detached
Feb 5 17:38:05: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is DOWN
Feb 5 17:38:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0, changed state to down
Feb 5 18:38:07: %GRPGE-6-SYNC_LOSS: Interface GigabitEthernet2/0: Sync OK
Feb 5 18:38:07: %GRPGE-6-LINE_STATE: Interface GigabitEthernet2/0: Line state OK
Feb
Mar 19 19:27:23: %OSPF-5-ADJCHG: Process 10, Nbr 202.183.64.5 on GigabitEthernet2/0 from LOADING to FULL, Loading Done
Mar 19 19:30:43: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is DOWN
Mar 19 19:30:50: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is UP
Mar 19 19:32:28: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is DOWN
Mar 19 19:32:35: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is UP
Mar 19 19:33:33: %OSPF-5-ADJCHG: Process 10, Nbr 202.183.64.5 on GigabitEthernet2/0 from LOADING to FULL, Loading Done
Mar 19 19:35:13: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is DOWN
Mar 19 19:35:15: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is UP
Mar 19 19:36:35: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is DOWN
Mar 19 19:36:37: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is UP
Mar 19 19:38:14: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is DOWN
Mar 19 19:38:21: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is UP
Mar 19 19:40:04: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is DOWN
Mar 19 19:40:08: %OSPF-5-ADJCHG: Process 10, Nbr 202.183.64.5 on GigabitEthernet2/0 from LOADING to FULL, Loading Done
Mar 19 19:40:25: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is UP
Mar 19 19:41:32: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is DOWN
Mar 19 19:41:51: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is UP
Mar 19 19:42:06: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is DOWN
Mar 19 19:42:18: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is UP
Mar 19 19:43:18: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is DOWN
Mar 19 19:43:21: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is UP
Mar 19 19:46:13: %OSPF-5-ADJCHG: Process 10, Nbr 202.183.64.5 on GigabitEthernet2/0 from LOADING to FULL, Loading Done
Mar 19 19:48:28: %OSPF-5-ADJCHG: Process 10, Nbr 202.183.64.5 on GigabitEthernet2/0 from LOADING to FULL, Loading Done
Mar 19 19:50:29: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is DOWN
Mar 19 19:50:39: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is UP
Mar 19 19:51:42: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is DOWN
Mar 19 19:51:46: %LDP-5-NBRCHG: LDP Neighbor 202.183.64.5:0 is UP
Mar 19 19:52:43: %OSPF-5-ADJCHG: Process 10, Nbr 202.183.64.5 on GigabitEthernet2/0 from LOADING to FULL, Loading Done
Mar 19 19:
pls go threw the attachment. i am sending u the logs of P router
rgds
ciscobuddy
5 Replies 5
adityakaul
G2/0 link is flapping due to which ur Ospf/Ldp Adj with nbr 202.183.64.5 is flapping.
Pls check the Link.
Mar 19 21:42:48: %GRPGE-6-SYNC_LOSS: Interface GigabitEthernet2/0: Loss of Sync
Mar 19 21:42:48: %GRPGE-6-RX_LOS: Interface GigabitEthernet2/0: Detected RX Loss of Signal
hi aditya,
i think u hv forgot to send the link
pls send it
rgds,
See the reason ur failing to have LDP Nbr Adj with 202.183.64.5 is bcoz ur gig2/0 link is flapping.
1. Is the ldp neighbour 202.183.64.5 connected thro intf g2/0.
2. Check the intf g2/0.
3. sh mpls ldp dis .
4. Check if ur able to reach this ip 202.183.64.5
http://www.cisco.com/en/US/partner/tech/tk436/tk428/technologies_tech_note09186a0080094b4e.shtml#subfirstfive
Maybe you should also check for bidirectional faults on link. I guess that you have fiber connections...try using the command "udld aggressive" on both sides on ports. This way you could se if RX or TX is bad. udld would put your interface on bad side, to down and make a trap to logg.
Another thing you could check is the MPLS MTU size on GE links. If your running MPLS/LDP, the MTU size may have to be changed, due to additional headers (BGP/IP/MPLS/LDP.....).
Cheers;
Harold Ritter
Try reseating the GBIC. I have seen issues with the same error messages being solved by doing so.
Hope this help,
