Map IPSec to MPLS using Radius
j.dolphin
Hi all, I have an IPSec to MPLS solution running on our PE router. Currently IPSec is (Cisco VPN client over the internet) connected with a given VRF based on the group name used. This works, but isn't really ideal for me, it would be much more elegant if forwarding to a particular VRF was based on a user's radius profile. I've done quite a bit of reading on cisco, the only thing I can find is here:
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1839/products_white_paper09186a00801541dd.shtml#wp1158006
And that's what I'm already running. Is my idea achievable? And if so, is it as simple as setting a VSA on a user's radius profile? Any pointers to documentation or configuration examples would be fantastic! Thanks for the help! Jerome
johansens
Level 4
Level 4
Hi there Jerome,
I have also been looking for a solution to this, and IIRC I found that the most feasible solution would be to convert to digital certificates.
Like this:
- Let the users apply for certificates for each of the VPN's they want to access
- Assign one certificate for each VPN for each user
- Do matching on some value in the certificate to assign the correct group
This way it's possible to revoke a users access to a specific VPN by revoking his/hers certificate on the CA.
Though I remember when I first implemented IPSec to Multi-VRF I had to use a AVpairs like this:
(from freeradius-config):
Cisco-AVPair == "lcp:interface-config=ip vrf forwarding MYVRF\\n ip unnumbered loopback 10\\n peer default ip address pool MYVRF-RA-POOL"
Did it help?
Hi Stig, thanks for the reponse, I'd prefer to stick with the Radius if possible.
I've added those changes to a test radius account. I'm assuming the Loopback interface referred to is in "MYVRF"?
So, the VPN client connects, but a "show ip route vrf MYVRF" on the IPSec to MPLS router doesn't show a route to the vpn client (I am using reverse-route in the dynamic map). However, "show ip route" shows a route to the VPN client address. This indicates to me it's being installed in the global routing table. Wierd.
And, from the VPN client machine, once logged in, I can indeed ping things in the global routing table. (As opposed to the VRF referred to in the AVPair). Any thoughts?
