MDT Data on NX-OS 5.2
Dirk Woellhaf
Hi everyone,
I´m trying to assign specific Customer-Multicast-Groups to an explicit MDT Data-Group via route-map which is configured on each mdt data-group.
Config looks like this
ip access-list High
10 permit ip any host 239.3.0.1/32
ip access-list Medium
10 permit ip any host 239.5.0.1/32
route-map High permit 10
match ip address High
route map Medium permit 10
match ip address Medium
vrf context Blue
mdt data 232.10.1.0/24 threshold 10 route-map High
mdt data 232.10.2.0/24 threshold 10 route-map Medium
My goal is, to have all multicast for 239.3.0.1 in 232.10.1.0/24 and all multicast for 239.5.0.1 in 232.10.2.0/24.
Right now, both customer-address are getting assigend to 232.10.2.0.
Any ideas?
regards, Dirk (Please rate if helpful)
Hello Dirk,
I can see that the route-map definition is not correct . The route-map must have 'match ip multicast group <>' for multicast control-plane filtering. Since the route-maps didn't have this match command and since route-maps are permit by default, only first route-map was getting selected ('Medium' was first route-map internally in mvpn).
Please modify the route-map config as follows:
match ip multicast group 239.3.0.1/32
match ip multicast group 239.5.0.1/32
and let me know the results ..
tthankap
Hello Dirk ,
Is this a partial config that you are showing ? I dont see the default MDT defind?
I am guessing that you have all these features enabled too
feature bgp
feature pim
feature mvpn
feature mpls l3vpn
feature tunnel
feature mpls ldp
Inculde these o/p
show ip pim mdt
show mvpn mdt route
show ip pim mdt receive & send
it is just a partial config. The "tunnel"-feature is not enabled by now.
here are the requested outputs:
S2# show ip pim mdt vrf Blue
MVPN Status Information for VRF "Blue" : MTI(mti8) Up
  Default MDT group 232.1.1.1 (Mode - SSM)
    Configured MTU: 1376 bytes, Actual MTU: 1376 bytes
    Configured tunnel source interface: loopback10
    Default BGP tunnel source interface: loopback10
    PIM Hello Interval: 30000 milliseconds
    PIM JP Interval: 60 seconds
    Data MDT Join Interval: 60 seconds
    Data MDT Switchover Interval: 3 seconds
    Data MDT Holddown Interval: 60 seconds
    Data MDT Timeout Interval: 240 seconds
    MDT Source address: 119.16.20.213 (iod loopback10)
    BGP RD: 192.16.20.213:100 (set)
    Data MDT Send Join Count: 6664
    Data MDT Received Join Count: 22201
     Data MDT: 232.10.2.0/24 threshold: 10 kbps route-map: Medium
     Data MDT: 232.10.1.0/24 threshold: 10 kbps route-map: High
S2# sh mvpn mdt route
MVPN MDT(Global) Route information for VRF "Blue":
(192.8.20.11, 232.1.1.1) [Refcount: 0]
(192.8.20.12, 232.1.1.1) [Refcount: 0]
(192.8.20.212, 232.1.1.1) [Refcount: 0]
(192.8.20.212, 232.10.2.0) [Refcount: 1]
(192.8.20.222, 232.1.1.1) [Refcount: 0]
(192.8.20.222, 232.10.2.0) [Refcount: 1]
(192.16.20.13, 232.1.1.1) [Refcount: 0]
(192.16.20.14, 232.1.1.1) [Refcount: 0]
(192.16.20.213, 232.1.1.1) [Refcount: 0]
(192.16.20.213, 232.10.2.0) [Refcount: 1]
(192.16.20.223, 232.1.1.1) [Refcount: 0]
S2# sh ip pim mdt send vrf Blue
MDT Data Groups Send List for vrf: Blue
C-Source        C-Group         MDT Source      MDT Group       Uptime
192.168.224.1   239.3.0.1       192.16.20.213   232.10.2.0      4d19h
S2# sh ip pim mdt rec vrf Blue
MDT Data Groups Received List for vrf: Blue
192.168.36.1    239.5.0.1       192.8.20.212    232.10.2.0      4d18h
192.168.36.1    239.5.0.1       192.8.20.222    232.10.2.0      4d18h
192.168.224.1   239.3.0.1       192.16.20.223   232.10.2.0      4d19h
Hello Dirk,
thanks for that hint!
It´s working now.
regards
Dirk
