ME3600X - Is MPLS on SVI interface supported?
2044418Puts
I would like to create an MPLS ring using several M3600X switches. The ring is created using the two 10 Gig interfaces on the ME3600X switches so I get a 10 Gig backbone. This is all done using the mpls ip command on the physical interfaces themselves. Nothing new here.
But on one location between two ME3600 nodes I need to have the MPLS ring traverse the users network. I am going to have lets say VLAN 99 assigned for the connection between the two ME3600 nodes to close this ring. Ofcourse the Vlan supports jumbo frames.
Like this:
                                                  <---------------------------VLAN 99 --------------------------->
ring .....10 Gb <-> ME3600X <-> 10Gb -------USERNETWORK-----------10 Gb <-> ME3600X <-> 10Gb ---> ring continues....
I also would like the user to be able to connect their VLANs to the VRF's I've created on my ME3600X nodes. So I essentially create a trunk interface on my ME3600 like this:
int vlan 1
ip vrf forwarding CUSTOMERDATA
ip addr....
  etc..
int vlan 99
ip mpls
etc.
Is this supported?
According to the ME3600X 15.3 configuration guide page 978 it is: "Enter interface configuration mode, and specify the Layer 3 interface connected to the MPLS network. Valid interfaces include 10GigabitEthernet1/1/1, GigabitEthernet1/1/2, and VLANs."
Has anyone tried this yet?
Thanks!
Lei Tian
Yes, that's supported.
U03360001(config-if)#do sh ver | in file
System image file is "flash:/me360x-universalk9-mz.153-1.S1/me360x-universalk9-mz.153-1.S1.bin"
interface Vlan10
ip vrf forwarding customer1
ip address 10.10.10.1 255.255.255.0
interface Vlan20
ip address 10.10.20.1 255.255.255.0
mpls ip
HTH,
Lei Tian
Lei Tian
interface Vlan10
interface Vlan20
mpls ip
HTH,
Lei Tian
Thanks for trying!
dal
Level 3
Level 3
Hello.
Sorry to open an old thread, but will putting MPLS configuration on SVI intefaces have any kind of performance issues compared to putting MPLS configuration directly on physical interfaces?
Thank you.
