Migrating Interface from Global to VRF
anasubra_2
Hi All,
We are trying to move interfaces from global routing table to VRF interface and during that process we are trying to move eigrp belonging to that interface from Global configuration to Address-family ipv4 instance of the eigrp under the VRF .
We are trying to figure out to populate passive-interface command under the address-family ipv4 vrf .But couldn't find the command supported in 12.2(18)SXF15 for Cisco 7600 router. Do we have to configure the passive-interface command alone in the global eigrp instead of address-family ?. Any help would be really appreciated.
Anantha Subramanian Natarajan
Harold Ritter
Anantha,
"passive-interface" under the "address-family" is only available starting with 12.2(33)SRB.
In the version you are currently running, configuring "passive-interface" globally will take effect even for specific VRF interfaces though.
Harold Ritter
Anantha,
Thank You hritter
