Missing next hop and output interface in LFIB
peymank64
In my mpls-forwarding table for a trial MPLS VPN network, I came across a few entries that are missing the outgoing interface and next hop information. I am curious to know how can such entry exist? What is the behavior when a packet with label 139 arrives at the router?
   Local      Outgoing   Prefix           Bytes Label   Outgoing   Next Hop
   Label      Label      or Tunnel Id     Switched      interface
   139        62         9543:1234010003:172.16.10.22/32   \
Vinit Jain
Could you please capture the below outputs:
- show mpls for <prefix> detail
- show ip cef <prefix> detail
Also, on which router are you seeing this issue and on what IOS version.
--Vinit
