more than single stream comming on multicast
sanjoy2006
Can anybody explain why I am getting so many multicast stream in a single igmp group .
Harold Ritter
In Any Source Multicast (ASM) mode, a receiver for a given multicast group will receive all streams from any source sending to that multicast group.
If this is not the behavior you want, you need to look at Source Specific Multicast (SSM), where the receiver not only the multicast group that it wants to join but also the specific source. This requires the receiver to support IGMPv3.
Thanks for reply .
Can we make it Source specific through putting "ip igmp static grooup and source" command on interface
You certainly can if the receiver doesn't support IGMPv3.
I will rate after testing ,just kidding.
