MPLS and bridging over FR
liviu.gheorghe
Has anyone seen this message:
The bridge-group command is unsupported on the interface:Serial2/0:0.24
when the MPLS feature has been enabled on
the main interface or one of its subinterfaces:Serial2/0:0.2
It used to work in 12.2, but after upgrade to 12.3.5b it's not.
I didn't find anything in the documentation about this problem.
Any help is appreciated.
Regards, LG
*** Please Rate All Helpful Responses ***
Harold Ritter
Level 12
Level 12
The combination of these two features is unsupported and has caused problems in the past. A check has been implemented by CSCdz75507, which will prevent the configuration of "bridge-group" if MPLS is configured or vice versa.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Harold Ritter
Level 12
Level 12
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
