MPLS Between Cisco and Juniper Not Working
chrisayres
MPLS is not really my thing but I am trying to get it working between a cisco 7200 and a third parties juniper. We can't get the 2 to see each other as MPLS neighbours. I am probably doing something fundamentally wrong but don't know what. Here is the revelant parts of the config
Cisco
mpls label protocol ldp
mpls ldp logging neighbor-changes
ip address x.x.x.x y.y.y.y
duplex auto
speed auto
media-type rj45
no negotiation auto
tag-switching ip
no cdp enable
Juniper (relevant int is 3/0/7) config attached
Any help or example of configs (cisco and Juniper would be good)
5 Replies 5
jayjorda
On the Cisco config you have pasted in, I don't see where you've defined an LDP router id.
Make sure you define an LDP router-id if you haven't already done so.
mpls ldp router-id Loopback0 or whatever interface you want to be the LDP router-id
Jay,
Thanks, There was no route to router id. Which now I think about it was exactly the same problem I had last time I played with MPLS
dili
Based on my experience, we find Juniper ENET MTU is 14 bit higher than Cisco. So, in my configuration, if we want to support MPLS MTU up to 1628 in Cisco, we have to set MTU 1642 in Juniper.
interface GigabitEthernet0/3
mtu 1628
load-interval 30
duplex full
speed 1000
media-type gbic
negotiation auto
tag-switching ip
end
ge-1/0/0 {
mtu 1642;
unit 0 {
family inet {
address x.x.x.x/30;
family mpls;
Hope it helps.
Brgds,
Dili
It looks like their rate-limiter is blocking ldp. Ask them to remove it temporarily to see if you can peer or do add the following.
set firewall filter Synetrix-Rate-Limit term my-ldp from source-port ldp
set firewall filter Synetrix-Rate-Limit term my-ldp then accept
set firewall filter Synetrix-Rate-Limit term ldp-to-me from destination-port ldp
set firewall filter Synetrix-Rate-Limit term ldp-to-me then accept
venu.brahma
Hi ,
A quick look at the juniper config is fine.
Can you enable the traceoptions under protocols ldp and view the log file (run file show /var/log/ldp-trace (ldp-trace.0, ldp-trace.1 etc) to see whether the ldp hello packets are sent / received on the interface or any errors in the log.
set protocols ldp traceoptions file ldp-trace size 1m files 10
set protocols ldp traceoptions flag packet
set protocols ldp traceoptions flag error
Also post the ldp-trace log here so that i can help you.
Venu
