mpls indirectly peers
ghtmoha153
Hello ,,
I have topology like Routers A-B-C, and i need to configure vc from A to C over mpls but i don't need configure it in mpls network . How i can configure that?
thanks
2 Accepted Solutions
friend then you need GRE,
the traffic send label over GRE
GRE run over IP core (i.e. the traffic will not drop in B because it can not read label header)
IOU1#show run
IOU1#show running-config
Building configuration...
Current configuration : 2292 bytes
! Last configuration change at 08:46:41 UTC Mon Jul 3 2023
version 15.5
hostname IOU1
boot-start-marker
boot-end-marker
no aaa new-model
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
redundancy
ip tcp synwait-time 5
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Tunnel0
ip address 5.0.0.1 255.255.255.0
mpls ip
tunnel source Ethernet0/0
tunnel destination 200.0.0.3
interface Ethernet0/0
ip address 100.0.0.1 255.255.255.0
interface Ethernet0/1
no ip address
shutdown
interface Ethernet0/2
no ip address
shutdown
interface Ethernet0/3
no ip address
shutdown
interface Ethernet1/0
no ip address
shutdown
interface Ethernet1/1
no ip address
xconnect 2.2.2.2 10 encapsulation mpls
interface Ethernet1/2
no ip address
shutdown
interface Ethernet1/3
no ip address
shutdown
interface Serial2/0
no ip address
shutdown
serial restart-delay 0
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface Serial3/0
no ip address
shutdown
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
router ospf 100
network 1.1.1.1 0.0.0.0 area 0
network 100.0.0.0 0.0.0.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 2.2.2.2 255.255.255.255 Tunnel0
mpls ldp router-id Loopback0
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
transport input none
end
IOU1#
IOU3#show mpls fo
IOU3#show mpls forwarding-table
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or Tunnel Id Switched interface
16 No Label l2ckt(10) 0 Et0/0 point2point
17 Pop Label 1.1.1.1/32 0 Tu0 point2point
18 No Label 100.0.0.0/24 0 Et1/1 200.0.0.2
IOU3#show run
IOU3#show running-config
! Last configuration change at 08:46:56 UTC Mon Jul 3 2023
version 15.5
hostname IOU3
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Tunnel0
ip address 5.0.0.2 255.255.255.0
mpls ip
tunnel source Ethernet1/1
tunnel destination 100.0.0.1
no ip address
xconnect 1.1.1.1 10 encapsulation mpls
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
ip address 200.0.0.3 255.255.255.0
no ip address
shutdown
no ip address
shutdown
interface Serial2/0
no ip address
shutdown
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface Serial3/0
no ip address
shutdown
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
router ospf 100
network 2.2.2.2 0.0.0.0 area 0
network 200.0.0.0 0.0.0.255 area 0
no ip http server
ip route 1.1.1.1 255.255.255.255 Tunnel0
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
IOU2#show run
IOU2#show running-config
Current configuration : 1968 bytes
version 15.5
hostname IOU2
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
redundancy
ip address 100.0.0.2 255.255.255.0
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
ip address 200.0.0.2 255.255.255.0
no ip address
shutdown
no ip address
shutdown
interface Serial2/0
no ip address
shutdown
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface Serial3/0
no ip address
shutdown
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
router ospf 100
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
7 Replies 7
first config GRE tunnel and then run MPLS over tunnel
what about this command
mpls ldp neighbor 1.1.1.1 targeted ?
one Q
B have config MPLS with both A and C?
No just A and C Configuring with mpls
Can you please give me configuration?
C7600
IOU1#show run
version 15.5
hostname IOU1
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
interface Tunnel0
mpls ip
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
no ip address
shutdown
no ip address
shutdown
interface Serial2/0
no ip address
shutdown
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface Serial3/0
no ip address
shutdown
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
router ospf 100
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
IOU1#
IOU3#show mpls fo
IOU3#show run
version 15.5
hostname IOU3
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
interface Tunnel0
mpls ip
no ip address
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
interface Serial2/0
no ip address
shutdown
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface Serial3/0
no ip address
shutdown
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
router ospf 100
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
IOU2#show run
version 15.5
hostname IOU2
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
redundancy
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
interface Serial2/0
no ip address
shutdown
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface Serial3/0
no ip address
shutdown
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
router ospf 100
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
