MPLS issues with redundant PE routers
alex.dersch
Level 4
Level 4
i'd like to set up an mpls lab. the layout of the gear is attached (mpls.jpg) At site A i have to PE router R4 and R6 which should have knowledge of the network 10.0.129.0/24 from site B. Router R1 is configured as a route reflector. the configuration of R1, R4, R5 and R6 are attached as well.
with the configuration
Routing Table R6
O E2     10.0.129.0 [110/1] via 172.16.128.9, 00:04:37, FastEthernet0/1.200
Routing table R4
B        10.0.129.0 [200/11] via 150.1.5.5, 00:05:00
a traceroute shows the path goes through R4 instead direkt through R1
Tracing the route to 10.0.129.1
VRF info: (vrf in name/id, vrf out name/id)
  1 172.16.128.9 4 msec 0 msec 4 msec
  2 172.16.128.1 [MPLS: Labels 19/29 Exp 0] 96 msec 100 msec 96 msec
  3 150.1.0.2 [MPLS: Labels 19/29 Exp 0] 68 msec 64 msec 68 msec
  4 172.16.129.9 [MPLS: Label 29 Exp 0] 64 msec 64 msec 64 msec
  5 172.16.129.10 40 msec *  36 msec
show bgp vpnv4 unicast all 10.0.129.0 indicates an error
Rack1R6# show bgp vpnv4 unicast all 10.0.129.0
BGP routing table entry for 200:1:10.0.129.0/24, version 63
Paths: (1 available, best #1, table CENTRAL, RIB-failure(17) - next-hop mismatch)
  Not advertised to any peer
  Local
    150.1.5.5 (metric 67) from 150.1.1.1 (150.1.1.1)
      Origin incomplete, metric 11, localpref 100, valid, internal, best
      Extended Community: RT:200:1 OSPF DOMAIN ID:0x0005:0x000000C80200
        OSPF RT:0.0.0.0:3:0 OSPF ROUTER ID:172.16.129.242:0
      Originator: 150.1.5.5, Cluster list: 150.1.1.1
      mpls labels in/out nolabel/29
Rack1R4#show bgp vpnv4 unicast all 10.0.129.0
BGP routing table entry for 200:1:10.0.129.0/24, version 146
Paths: (1 available, best #1, table CENTRAL)
  Local
any ideas what i have to do in order to have a redundant path towards site B?
thanks in advanced
Alex
2 Accepted Solutions
Akash Agrawal
Hi Alex,
I think you still have redundancy via R6, but BGP route on R6 is not getting installed in routing table because it is having OSPF route with lesser AD value. If R4 goes down, R6 will loose OSPF route for 10.0.129.0/24 coming from R4, install BGP route ,redistribute this to OSPF and will advertise it to SW4.
Routing Table R6
  Local
Then change OSPF admin distance (above 200) to prefer iBGP routes on PE routers.
Router(config-router)#distance ospf
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
8 Replies 8
Akash Agrawal
Hi Alex,
Routing Table R6
  Local
Hi Akash,
that's true, i just switched off the R4 and the route was installed properly in the routing table of R6.But it's not what i actually want. so no chance for load balancing?
regards
alex
blau grana
Level 7
Level 7
Hello Alex,
Delete capability vrf-lite from OSPF configuration on both PEs and you will see both PE to use BGP learned routes. I do not see any point to use capability vrf-lite in your scenario.
Best Regards
i need the capability vrf-lite, i'll have more vrf's later.
regards
alex
Best Regards
Thanks a lot, it's working now.
Harold Ritter
Hi Alex,
There is a few things I noticed while looking at your configurations. On R4 and R6 you redistribute between BGP and OSPF without any kind of filtering, which means routes received from BGP are redistributed in OSPF and these same routes could potentially be redistributed back into BGP on the other PE. It is usually best practice to put some kind of filtering in place when doing mutual redistribution.
As for the specific issues that you are seeing on R6, the rib(17) error code indicates that this route is already installed in the RIB from another protocol with a lower admin distance. The "next-hop mistmatch" means that the other route does not have the same next hop as the BGP learned route.
Would it be possible for you to provide us with the output of a "show ip route vrf CENTRAL 10.0.29.0 255.255.255.0".
Hello Harold,
here are the outputs
Rack1R4#show ip route vrf CENTRAL 10.0.129.0 255.255.255.0
Routing Table: CENTRAL
Routing entry for 10.0.129.0/24
  Known via "bgp 100", distance 200, metric 11, type internal
  Redistributing via ospf 200
  Advertised by ospf 200 subnets
  Last update from 150.1.5.5 02:19:17 ago
  Routing Descriptor Blocks:
  * 150.1.5.5 (default), from 150.1.1.1, 02:19:17 ago
      Route metric is 11, traffic share count is 1
      AS Hops 0
      MPLS label: 29
      MPLS Flags: MPLS Required
Rack1R4#
  Known via "ospf 200", distance 110, metric 1
  Tag Complete, Path Length == 1, AS 100, , type extern 2, forward metric 10
  Redistributing via bgp 100
  Last update from 172.16.128.9 on FastEthernet0/1.200, 02:19:52 ago
  * 172.16.128.9, from 172.16.128.242, 02:19:52 ago, via FastEthernet0/1.200
      Route metric is 1, traffic share count is 1
      Route tag 3489661028
Rack1R6#
