MPLS L2VPN ASR9K and 7600
1336
Am having problem bringing up mpls l2vpn between asr9k and 7609 router . Below is my config. The interfaces are up, the vc working, but can't ping across.
AS9K
interface GigabitEthernet0/2/0/6.609 l2transport
encapsulation dot1q 609
rewrite ingress tag pop 1 symmetric
mtu 1526
pw-class TST
  encapsulation mpls
   transport-mode vlan
xconnect group TST
  p2p TST
   interface GigabitEthernet0/6.609
   neighbor 2.2.2.2  pw-id 609
    pw-class TST
7609
interface gig 3/4.609
xconnect 1.1.1.1 609 encapsulation mpls
***OUTPUT FROM ASR9K********
RP/0/RSP0/CPU0#sh l2vpn xconnect pw-class TST detail
Group X,X, state is up; Interworking none
  AC: GigabitEthernet0/6.609, state is up
    Type VLAN; Num Ranges: 1
    VLAN ranges: [905, 905]
    MTU 1512; XC ID 0x1040003; interworking none
    Statistics:
      packets: received 735789487, sent 725878036
      bytes: received 405747931393, sent 184926449749
      drops: illegal VLAN 0, illegal length 0
  PW: neighbor 2.2.2.2, PW ID 609, state is up ( established )
    PW class ENS, XC ID 0xc0000003
    Encapsulation MPLS, protocol LDP
    Source address 1.1.1.1
    PW type Ethernet VLAN, control word disabled, interworking none
    PW backup disable delay 0 sec
    Sequencing not set
    PW Status TLV in use
      MPLS         Local                          Remote
      Label        17442                          847
      Group ID     0x80003c0                      0x0
      Interface    GigabitEthernet0/6.609     uknown
      MTU          1512                           1512
      Control word disabled                       disabled
      PW type      Ethernet VLAN                  Ethernet VLAN
      VCCV CV type 0x2                            0x2
                   (LSP ping verification)        (LSP ping verification)
      VCCV CC type 0x6                            0x6
                   (router alert label)           (router alert label)
                   (TTL expiry)                   (TTL expiry)
    Incoming Status (PW Status TLV):
      Status code: 0x0 (Up) in Notification message
    Outgoing Status (PW Status TLV):
    MIB cpwVcIndex: 3221225475
    Statistics:
      packets: received 725878036, sent 735789487
      bytes: received 184926449749, sent 405747931393
*******7609 OUTPUT*******
Local interface: Gi1/3.609 up, line protocol up, Eth VLAN 609 up
  Destination address: 1.1.1.1, VC ID: 609, VC status: up
    Output interface: Gi2/4, imposed label stack {0 151644}******************This is my problem no imposed label on 7609
    Preferred path: not configured
    Default path: active
    Next hop: 10.198.64.21
  Create time: 00:00:16, last status change time: 00:00:16
  Signaling protocol: LDP, peer 1.1.1.1 up
    Targeted Hello: 2.2.2.2(LDP Id) -> 1.1.1.1, LDP is UP
    Status TLV support (local/remote)   : enabled/supported
      LDP route watch                   : enabled
      Label/status state machine        : established, LruRru
      Last local dataplane   status rcvd: No fault
      Last local SSS circuit status rcvd: No fault
      Last local SSS circuit status sent: No fault
      Last local  LDP TLV    status sent: No fault
      Last remote LDP TLV    status rcvd: No fault
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local 505, remote 151644
    Group ID: local 0, remote 134218688
    MTU: local 1508, remote 1508
    Remote interface description: GigabitEthernet0_6_.609
  Sequencing: receive disabled, send disabled
  Control Word: Off (configured: autosense)
  SSO Descriptor: 1.1.1.1/609, local label: 505
    SSM segment/switch IDs: 57633/24673 (used), PWID: 28772
  VC statistics:
    transit packet totals: receive 3, send 0
    transit byte totals:   receive 216, send 0
    transit packet drops:  receive 0, seq error 0, send 0
Harold Ritter
Hi Ogungbenro,
Can you please post the output of a "show ip cef 1.1.1.1 int" from the 7609.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Hello ogungbenro wale,
Would you be so kind to verify the output form 7600, since the config part does not correspond to VC you provided output for:
interface gig 3/4.609 <=
Local interface: Gi1/3.609 up, line protocol up, Eth VLAN 609 up <=
-- Best regards, Dmitry Skotnikov
