MPLS label range
atsadikov
Does any body know if during the CCIE lab configuration of MPLS label ranges configuration effecting on the score if CISCO workbook doesnot asking for it?
I am doing this becouse it is easy to recognize which router created what routes.
Peter Paluch
I am afraid this question can be answered satisfactorily only by a proctor.
My personal - and totally unwarranted - opinion is that if the lab assignment does not call for specific label ranges then they can be arbitrary and will not be specially graded. Because of inherent randomness in the order the labels are assigned anyway, the lab scoring should not take particular label values into account.
Then again, while defining a unique label range for a particular router is certainly a helpful approach, as a prospective expert, you are expected to be fluent and well-accustomed to scenarios with overlapping label ranges, and I suggest you practice that skill as well.
Best regards,
Peter
Giuseppe Larosa
Hello Atsadikov,
given the limited label space this is not feasible in real world  when you have tens to hundreds of PE and P nodes,so I would get used to this fact
Hope to help
Giuseppe
