7600 power unit issue
ravisambaji
Hi Friends,
i have PWR-4500-DC   power supply module on my cisco 7606-S box. The image is 15.0S. below is the outpot of show power. it shows 2960.58 watts whereas it should be showing 4500 w. pls help on this
JBJMMUXXXXM001C7A001#show power
system power redundancy mode = redundant
system power total =     2960.58 Watts (70.49 Amps @ 42V)
system power used =      1469.58 Watts (34.99 Amps @ 42V)
system power available = 1491.00 Watts (35.50 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    PWR-4500-DC        2960.58 70.49  OK     OK     on
2    PWR-4500-DC        2960.58 70.49  OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    FAN-MOD-6SHS        180.18  4.29  OK
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    7600-ES+20G3CXL     304.50  7.25   304.50  7.25  on    on
2    7600-ES+20G3CXL     304.50  7.25   304.50  7.25  on    on
5    RSP720-3CXL-GE      340.20  8.10   340.20  8.10  on    on
6    unknown             340.20  8.10   340.20  8.10  on    on
Ravi
Had the same problem some weeks ago, with a 7609-S and PWR-4000-DC
I found that all 3 input wires needs to be connected, anf with only two connected lower power will be reported.
http://www.cisco.com/en/US/docs/routers/7600/Hardware/Chassis_Installation/7600_Series_Router_Installation_Guide/remrep.html
Guess the same issue applies for your configuration
Jon Harald Bøvre
Hello Ravi,
Try below two command and see if both output watts are close. If not it is not alarming condition
If close than you can chane power redundancy mode to combined but only if there is log message of low power input
#sh power used
system power used =      1794.66 Watts (42.73 Amps @ 42V)
#sh power available
system power available = 3976.98 Watts (94.69 Amps @ 42V)
You should also consider input given by jon because he is having some practical experience
Mahesh
Check notes below this paragraph:
Power may run in 2 modes: 2700W or 4000W
Connecting 2 DC connections provides 2700W
Connecting 3 DC connections provides 4000W
Selection is auto-sense
http://www.cisco.com/en/US/docs/routers/7600/Hardware/Chassis_Installation/7600_Series_Router_Installation_Guide/remrep.html#wp1107253
Jon Harald Bøvre
