MPLS LDP on Cisco2921
alexandru.cacean
Community Member
Hello. We have cisco 2921:
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M1, RELEASE SOFTWARE (fc1)
Technology Package License Information for Module:'c2900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Permanent     securityk9
uc            None          None          None
data          None          None          None
I need to test "Configuring MPLS LDP Autoconfiguration with OSPF Interfaces" like this link:
http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_ldp_autoconfig.html
but in the global configuration mode "mpls ip" is not active:
C2921(config)#mpl?
% Unrecognized command
In the documentation I find that C2921 support MPLS, what is the problem ?
Hi Alex,
As you can see from the output you have posted yourself, it does not:
uc            None          None          None
data          None          None          None
This is also described in the following document:
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985_ps10537_Products_White_Paper.html#wp9000809
You will need to obtain the DATA license in order to use the MPLS support.
Best regards,
Peter
Peter Paluch
Alex,
I suspect that the MPLS is supported in the DATA license. You will need to purchase the DATA license, or activate a temporary (evaluation) license if such is available.
Best regards,
Peter
our router have SEC/K9 license, this license not include Data feature ?
Hi Alex,
uc            None          None          None
data          None          None          None
Best regards,
Peter
thanks, you are right...
