I have an LDP session configured over my P2P interface and it is not coming up . What can be the reason ? I can ping the P2P IP adddress
interface FastEthernet4/1
ip address 10.10.0.46 255.255.255.252
ip ospf network non-broadcast
ip ospf cost 10
mpls ip
Router #sh mpls ldp neighbor
interface GigabitEthernet3/4.1254
encapsulation dot1Q 1254
ip address 10.10.0.45 255.255.255.252
ip ospf cost 10
mpls ip
Haris P
i reconfigure mpls ldp id ,but nothing happened !!!!!!!!!
no mpls ldp router-id Loopback1
In the posted solutions i haven't seen where you actually confirmed that MPLS is indeed running on your tunnel interfaces
sh mpls interfaces will show you the current status of the attached interface.
This is a critical step before verifying any thing else along the path. If your tunnel interface is displaying no or nothing under IP, run the command under the interface mpls ip then secondly you can hard code mpls label protocol ldp if you find it fitting.
Harris,
Replace the word Loopback1 with the IP Address /32 mask
Craig
there is no option to mpls ldp router-id to X.X.X.X with a /32 network mask , i have onkly the options below
Router1(config)#mpls ldp router-id ?
ATM ATM interface
Async Async interface
BVI Bridge-Group Virtual Interface
CDMA-Ix CDMA Ix interface
CTunnel CTunnel interface
Dialer Dialer interface
FastEthernet FastEthernet IEEE 802.3
Group-Async Async Group interface
Lex Lex interface
Loopback Loopback interface
MFR Multilink Frame Relay bundle interface
Multilink Multilink-group interface
Null Null interface
Port-channel Ethernet Channel of interfaces
Tunnel Tunnel interface
Vif PGM Multicast Host interface
Virtual-PPP Virtual PPP interface
Virtual-Template Virtual Template interface
Virtual-TokenRing Virtual TokenRing
XTagATM Extended Tag ATM interface
Harris,
Please enter sh mpls interface
Craig
#sh mpls interfaces
Interface IP Tunnel Operational
FastEthernet4/1 Yes (ldp) No Yes
#sh mpls interfaces
GigabitEthernet3/4.325 Yes (ldp) No No No Yes
While pinging from R1 with 224.0.0.2 ,from R2 im getting reply but not vice versa
R1#ping 224.0.0.2
Sending 1, 100-byte ICMP Echos to 224.0.0.2, timeout is 2 seconds:
Reply to request 0 from 10.10.0.45, 20 ms
SHDSL_GEF3#ping 224.0.0.2
Just disable igmp snooping on the middle switches.
If you are having connection through switches then this solution can help to bring the LDP neighbor ship up immediately.
