MPLS MTU issues
Kaushik Ray
Hello I am facing a strange issue and would be grateful to have any advice on this please.
I have an existing setup where Site A and site B are connected within an MPLS setup:
When I ping from Site B to site A with size 1500 it works no problem
ping vrf Data1 192.168.230.2 size 1500
Sending 5, 1500-byte ICMP Echos to 192.168.230.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 496/496/500 ms
there is a new site C that has come up with a new link as a back up of site B but when i ping it only allows ping of 1496 and not anything more.
ping vrf Data1 192.168.230.2 size 1496
Sending 5, 1496-byte ICMP Echos to 192.168.230.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 500/502/504 ms
ping vrf Data1 192.168.230.2 size 1497
Sending 5, 1497-byte ICMP Echos to 192.168.230.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
I have compared the configs and they are setup with same MPLS mtu size show as follows
Site B
interface FastEthernet2/0
no ip address
duplex full
speed 100
mpls label protocol ldp
mpls ip
mpls mtu 1524
end
Site C
interface FastEthernet0/1
no ip address
ip flow ingress
load-interval 30
duplex full
speed 100
mpls ip
mpls mtu 1524
end
I have asked the provider of the circuit and they say that the MTU sizes on their devices are 1530 same as the link from site B because the switches connected to both the above routers have system MTU as 1530.
I cannot find out what the issue could be ?
any help on this will be much appreciated.
many thanks in advance.
Sudeep Valengattil
Hi Kaushik,
Since I'm not aware of the topology and the routers involved b/t source and destination, I would ask you to folow below streps to Tshoot this as a first step
1. Find the direction in which traffic is failing
ping from C to A and see if the traffic is reaching A by doing "debug icmp" or "show ip traffic | in echo"
2. Once direction is determined, follow by each hop and check the MTU (with ping tests and also verify config)
Try to focus on device/interfaces which does not come in path of B->A (working)
PE-B/A# ping hop1ip size 1500
PE-B/A# ping hop2ip size 1500
3. Check if anywhere mpls mtu is missing.  Also check for situation where we use more than one label.
Regrds,
Sudeep
Site A is 7206
Site B is 7206 and
Site C is 2811
1) Directions failing is both directions
When i debug the ip icmp echo
it comes back on Site A router as
*Oct 24 14:08:57.872 UTC: ICMP: dst (10.181.0.1) port unreachable rcv from 10.181.3.105
the utilization on Site C is as follows: could it be a reason why large sized packets are failing?
100 **  *       * ** *  * *    *  *      *   *         *        *   **     *
90 **  *       * ***** * *    *  *      *  *** *      * *      *   ****   *
80 #******    ** **###** **   ****      ****#*** *   ****     **  *##**  **
70 #####***   ** *######********#**   * **####***#*****#**    **  *###***##
60 #######********###########*#####*******###############***  ****#########
50 ##########**#####################***####################******##########
40 ########################################################################
30 ########################################################################
20 ########################################################################
10 ########################################################################
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
                  * = maximum CPU%   # = average CPU%
I have checked the configs and compared with the Site B configs and they seem to good. I have validated with someone else as well.
How do I check if there are places where more than one label is being used?
