MPLS on VSS
ar
Hi.
Is it good by design to implement MPLS on VSS switches acting as MPLS PE?
VSS is a good technique for edge routers but I'm thinking if running MPLS on top of it will be a good idea?
Though it says in the VSS docs that it supports MPLS/IPv6,  I havent seen any related docs for MPLS implementation.
thanks
yashfaqu
Well Yes, There are designs where Customer configure DCI on VSS over A-VPLS.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/white_paper_c11_493718.html#wp9000242
Thanks. What about configuration guide? Just the same with the standard MPLS configurations?
I want also to extend VRFs on VSS.
Yes, for L3VPN, it will be standard MPLS configuration.
