MPLS over L2TP
rana_beech
Has anyone connected two PE routers over L2TP tunnel? I have a case where I have to go through a third party L3 network. I would like to exchange LDP over the tunnel. Can someone point to a good doc on the web or provide a sample config.
thanks
Arana
Harold Ritter
Level 12
Level 12
Arana,
Here's the link to the documentation for l3vpn over l2tpv3 tunnels.
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/csgl3vpn.html
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Hritter,
Is the configuration for CE-PE? I was talking for PE-PE. I need to exchange LDP with the PE routers just like a leased line, only that there is an IP netwokr in between.
Arana
Arana,
The solution I provided is indeed for the PE-PE interconnection and is ususally used when you don't already have an MPLS core but that you want to deliver l3vpn services.
If you already have an MPLS core but that you want your traffic to traverse a network that is not MPLS enabled, you could just do MPLS over a GRE tunnel:
int tu0
ip address x.x.x.x y.y.y.y
tunn source s.s.s.s
tunn destination d.d.d.d
mpls ip
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
