MPLS packet drops
1pgordo
I have two ASR9000 running 5.1.3. They are connected back to back using mpls protocol.
When i enter the command 'show mpls forwarding summary' i've got the following output:
        sh mpls forwarding summary
        Pkts dropped:    46958
        Failed lookups:  447
Does anyone know wich could be the cause for the drops and the failed lookups?
Vinit Jain
Could you please paste the complete output.
The usual cases when you see the packet drops is when the LSP is not complete or the LFIB doesnt knows where to forward the packet. THis can be seen when there are LDP neighbor flaps seen on the router.
Vinit
--Vinit
Hi Vinit,
follows the complete output as you asked for:
Fri May 27 09:20:42.450 UTC
Forwarding entries:
   Label switching: 10, protected: 0
   MPLS TE tunnel head: 0, protected: 0
   MPLS TE midpoint: 0, protected: 0
   MPLS TE internal: 0, protected: 0
   MPLS P2MP TE tunnel head: 0
   MPLS P2MP TE tunnel midpoint/tail: 0
   MPLS P2MP MLDP tunnel head: 0
   MPLS P2MP MLDP tunnel midpoint/tail: 0
Forwarding updates:
      p2p updates: 1141
Labels in use:
   Reserved: 4
   Lowest: 0
   Highest: 16009
   Deleted stale label entries: 0
Pkts dropped:    47800
Pkts fragmented: 0
Failed lookups:  447
Best regards,
PGordo
