MPLS-PE Always automatically Reboot
gilanx2010
I have a Problem with one PE using Cisco 7206VXR (NPE-G2), The PE only reboot automatically, The following log in PE during and after reboot, What
what causes this problem occurs ? We already replace device the PE using the same type of router but not solve the problem.
before reboot
17:28:15  UTC Sun Jun 12 2011: Unexpected exception to CPU: vector 300, PC = 0x27E277C ,  LR = 0xBBE0B8
-Traceback=  27E277C BBE0B8 C0F74C BBF408 BBF8D0 FBD9B0 FBDD94 FBF4F4 FC0144 23CA5EC
CPU  Register Context:
PC   = 0x027E277C  MSR = 0x00009032  CR  = 0x42004044  LR    =  0x00BBE0B8
CTR  = 0x014A7220  XER = 0x20000000  DAR = 0x7CB142AA  DSISR =  0x40000000
DEC  = 0x000207CB  TBU = 0x0000052C  TBL = 0x80A549C9  MSSCR0=  0x00000000
R0   = 0x00BBF408  R1  = 0x05853FE8  R2  = 0xFFF3B1C0  R3    =  0x384D9BD1
R4   = 0x7CB142AB  R5  = 0x0000000F  R6  = 0xF1000014  R7    =  0x03CA7ACC
R8   = 0x384D9BD0  R9  = 0x000000FF  R10 = 0x7CB142A9  R11   =  0x03D10000
R12  = 0x00009032  R13 = 0xFFF3C560  R14 = 0x00FC00C8  R15   =  0x00000000
R16  = 0x00000000  R17 = 0x00000000  R18 = 0x00000000  R19   =  0x00000000
R20  = 0x00000001  R21 = 0x00000000  R22 = 0x00000000  R23   =  0x06348B14
R24  = 0x059879C8  R25 = 0x03D10000  R26 = 0x00000000  R27   =  0x00000000
R28  = 0x00000001  R29 = 0x0431AF9C  R30 = 0x384D9BD0  R31   =  0x7CB142A6
Writing  crashinfo to bootflash:crashinfo_20110612-172815-UTC
Gilang.
Ivan Krimmel
Level 7
Level 7
Gilang,
please open a TAC case for that. You will need to provide a 'sh tech' and the crashinfo file to start with.
Try:
https://www.cisco.com/cgi-bin/Support/OutputInterpreter/home.pl
copy and paste your show tech/Crash file.
if it doesnt help, CISCO TAC is always there to serve their customers
