Hi kunal,
Please find answers
1- yes psedowire is used for MPLS l2 vpn solutions and not for L3. Moreover it is layer2 independent.means you can run any protocol end to end.
before packet enters the l2 domain.
http://tools.ietf.org/html/draft-kompella-l2vpn-l2vpn-00
2- yes config do not contains any vrf stuff..it is purely l2 stuff
l2tpv3: http://tools.ietf.org/html/draft-ietf-mpls-over-l2tpv3-03
There are many doc. for other technology ..you can try google for details
3- Yes it is true that FRR is not needed to reroute if you want your premium customers running voice to keep on complaining. .he he he.
Ok..See all redundant path labels are stored in LIB and the best one is stored in LFIB..so even if you do not use FFR you will reroute traffic
but it takes more time to know that there is link failure with help of only IGP.
FRR offers 50ms failover time..So if your network is having voice customer (which demands immediate failover) FRR is better choice.
Hope this is helpful to you
Mahesh
