MPLS routed pseudowire between ASR9k and 7600 with LAN cards
abrizs
There is a need to extend L2 connections from an existing 7600 with LAN cards to a new ASR9001 and configure IP address on that connection.
To my understanding this looks something like "Pseudowire Headend".
ASR9k:
l2vpn
xconnect group test
p2p test
interface PW-Ether555
neighbor 192.168.0.1 pw-id 555
mtu 9216
vrf MGMT
ipv4 address 172.30.2.1 255.255.255.252
attach generic-interface-list test
interface Bundle-Ether1
interface TenGigE0/0/0/1
7600:
interface TenGigabitEthernet3/4.555
encapsulation dot1Q 555
xconnect 192.168.0.2 555 encapsulation mpls
mtu 9202
The problem here is that ASR thinks that everything is fine:
Group test, XC test, state is up; Interworking none
AC: PW-Ether555, state is up
Type PW-Ether
Interface-list: test
Replicate status:
Te0/0/0/1: success
BE1: success
MTU 9202; interworking none
Internal label: 16020
Statistics:
packets: received 0, sent 60
bytes: received 0, sent 2532
PW: neighbor
192.168.0.1
, PW ID 555, state is up ( established )
PW class not set, XC ID 0xc0000001
Encapsulation MPLS, protocol LDP
Source address 172.30.0.2
PW type Ethernet, control word disabled, interworking none
PW backup disable delay 0 sec
Sequencing not set
PW Status TLV in use
MPLS Local Remote
Label 16021 45
Group ID 0x160 0x0
Interface PW-Ether555 unknown
MTU 9202 9202
Control word disabled disabled
PW type Ethernet Ethernet
VCCV CV type 0x2 0x2
(LSP ping verification) (LSP ping verification)
VCCV CC type 0x6 0x6
(router alert label) (router alert label)
(TTL expiry) (TTL expiry)
Incoming Status (PW Status TLV):
Status code: 0x0 (Up) in Notification message
Outgoing Status (PW Status TLV):
MIB cpwVcIndex: 3221225473
Create time: 19/02/2013 08:51:23 (07:59:29 ago)
Last time status changed: 19/02/2013 16:50:00 (00:00:52 ago)
Last time PW went down: 19/02/2013 09:05:10 (07:45:42 ago)
Statistics:
However at the same time 7600 is unhappy:
BIP-STO1#sh xconnect int te3/4.555 detail
Legend: XC ST=Xconnect State S1=Segment1 State S2=Segment2 State
UP=Up DN=Down AD=Admin Down IA=Inactive
SB=Standby HS=Hot Standby RV=Recovering NH=No Hardware
XC ST Segment 1 S1 Segment 2 S2
DN ac Te3/4.555:555(Eth VLAN) UP mpls 192.168.0.2:555 DN
Interworking: ethernet Local VC label 45
Remote VC label 16021
What am I missing here? Is this even the right approach to reach the goal?
I succeeded in a similar task where there was HP 5800 at the other end of L2 circuit. I used bridge domain, VPLS and BVI interface in that case. Unfortunately VPLS is not an option for 7600 with LAN cards.
0 Replies 0
