MPLS TE and badwidth value
ima imtiger
hello,
my question is about mpls TE.
i have the following topology
R4 - 100Mbps - R3 - 100Mbps - R2 - 155Mbps - R1
i establish an mpls TE tunnel between R4 and R1 (10.1.1.1) with a bandwidth value of 10Mbps
when i do "show mpls traffic-eng topology path tunnel0", i expect to see bandwith values decremented by 10Mbps which is reservation value.
but the output of the command is like this
R4#show mpls traffic-eng topology path tunnel0
Query Parameters:
Destination: 10.1.1.1
Bandwidth: 10000
Priorities: 1 (setup), 1 (hold)
Affinity: 0x0 (value), 0xFFFF (mask)
Query Results:
Min Bandwidth Along Path: 100000 (kbps)
Max Bandwidth Along Path: 155000 (kbps)
Hop 0: 10.1.24.4 : affinity 00000000, bandwidth 100000 (kbps) i expect ti see 90000
Hop 1: 10.1.12.2 : affinity 00000000, bandwidth 100000 (kbps) i expect ti see 90000
Hop 2: 10.1.12.1 : affinity 00000000, bandwidth 100000 (kbps) i expect ti see 90000
Hop 3: 10.1.13.1 : affinity 00000000, bandwidth 155000 (kbps) i expect ti see 145000
Hop 4: 10.1.1.1
can you help me please the understand this problem ?
thanks
BR
ima
saurjosh
Router1# show mpls traffic-eng topology path Tunnel1 bandwidth 1000
Query Parameters:
  Destination:10.112.0.12
    Bandwidth:1000
   Priorities:1 (setup), 1 (hold)
     Affinity:0x0 (value), 0xFFFF (mask)
Query Results:
  Min Bandwidth Along Path:2000 (kbps)
  Max Bandwidth Along Path:5000 (kbps)
  Hop  0:10.1.0.6       :affinity 00000000, bandwidth 2000 (kbps)
  Hop  1:10.1.0.10      :affinity 00000000, bandwidth 5000 (kbps)
  Hop  2:10.43.0.10     :affinity 00000000, bandwidth 2000 (kbps)
  Hop  3:10.112.0.12
Field
Description
Destination
IP address of the path's destination.
Bandwidth
Amount of available bandwidth that a suitable path requires.
Priorities
Setup and hold priorities used to acquire bandwidth.
Affinity
Link attributes for which the path has an affinity.
Minimum amount of bandwidth configured for a path.
Maximum amount of bandwidth configured for a path.
Hop
Information about each link in the path.
Can you share your tunnel config please?
I am not sure if you are looking for something like this.
Router# show ip rsvp interface
interface    rsvp       allocated  i/f max  flow max sub max  VRF
Et0/0        ena        300K       1M       1M       0
Et0/1        ena        100K       1M       1M       0
Et1/0        ena        200K       1M       1M       0
Et1/1        ena        0          1M       1M       0
Et1/2        ena        0          1M       1M       0
Saurabh
MAC adress naming?
tunnel mpls traffic-eng auto-bw {frequency } {max-bw } {min-bw }
Mark Deibert wrote:
MAC adress naming?
