10-23-2015 02:54 AM
Hi all. Does anybody know how to establish RSVP path between Cisco and Extreme X460 XOS 15.6 switches?
When i tried this I have received errors on C7600:
LABMPE01#sh ip rsvp counters int g2/0/10
GigabitEthernet2/0/10 Recv Xmit Recv Xmit
Path 5104 5154 Resv 5154 0
PathError 5154 5104 ResvError 0 5154
PathTear 5104 5154 ResvTear 0 0
ResvConf 0 0 RTearConf 0 0
Ack 0 0 Srefresh 0 0
Hello 10259 10052 IntegrityChallenge 0 0
IntegrityResponse 0 0 DSBM_WILLING 0 0
I_AM_DSBM 0 0 Errors 0 0
LABMPE01#sh ip rsvp neighbor
Neighbor Encapsulation Time since msg rcvd/sent
172.25.255.54 Raw IP 00:00:06 00:00:06
172.25.255.58 Raw IP 00:00:06 00:00:06
* Neighbors inactive for more than one hour are not shown.
Use the "inactive" keyword to display them.
LABMPE01#deb ip rsvp err
RSVP errors debugging is on
LABMPE01#
*Oct 23 01:00:33.008: RSVP: 212.176.120.210_0->212.176.120.209_1[Src] {7}: POLICY-COPS - no active COPS server entry for this sessio
n. Ignoring
*Oct 23 01:00:33.012: RSVP: 212.176.120.210_0->212.176.120.209_1[Src] {7}: POLICY-COPS - no active COPS server entry for this sessio
n. Ignoring
*Oct 23 01:00:33.028: RSVP: Unsupported/invalid object; length 36 bytes:
*Oct 23 01:00:33.028: 0000 00 24 09 02 00 00 00 07 05 00 00 06 7F 00 00 05 ................
*Oct 23 01:00:33.028: 0010 47 74 24 00 44 7A 00 00 00 00 00 00 00 00 00 14 Gt..Dz..........
*Oct 23 01:00:33.028: 0020 00 00 23 28 ....
*Oct 23 01:00:33.028: RSVP: 212.176.120.210_0->212.176.120.209_1[Src] {7}: POLICY-COPS - no valid COPS server entry for this session
. Ignoring
*Oct 23 01:00:33.028: RSVP: session 212.176.120.209_1[212.176.120.210] (7): Problem parsing RESV message: MISFORMATTED object (9) C-
Type (2)
*Oct 23 01:00:33.028: RSVP: session 212.176.120.209_1[212.176.120.210] (7): IGNORING bad Resv Message for 212.176.120.209(GigabitEth
ernet2/0/11) from 172.25.255.54
*Oct 23 01:00:33.036: RSVP: 212.176.120.210_0->212.176.120.209_1[Src] {7}: POLICY-COPS - no valid COPS server entry for this session
. Ignoring
and Extreme X460 errors:
* LABMPE09.8 # sh mpls rsvp-te interface "to_LABMPE01" det
VLAN Name : to_LABMPE01
Local IP Address : 172.25.255.54
MPLS Admin Status : Enabled
MPLS Oper Status : Enabled
RSVP-TE Admin Status : Enabled
RSVP-TE Oper Status : Enabled
RSVP-TE Up-Time : 0d:21h:30m:26s
# Neighbors : 0
Receive CIR : 1000 Kbps
Transmit CIR : 1000 Kbps
TE Metric : Use IGP Cost/Metric
Hello Interval : 3 seconds
Refresh Time : 30 seconds
Hello Keep Multiplier : 4
Refresh Keep Multiplier : 4
Summary Refresh : Disabled
Summary Refresh Time : 3000 milliseconds
Bundle Message : Disabled
Bundle Message Time : 1000 milliseconds
Dir Pool CIR Available (Mbps per priority level)
0 1 2 3 4 5 6 7
Rx 1 1 1 1 1 1 1 1 1
Tx 1 1 1 1 1 1 1 1 1
(Rx)Receive Bandwidth (Tx)Transmit Bandwidth
Message Sent Received
PATH 2579 2537
PATH_TEAR 2579 2537
PATH_ERR 2537 2579
RESV 2537 0
RESV_TEAR 0 0
RESV_ERR 0 2537
RESV_CONFIRM 0 0
SUMMARY_REFRESH 0 0
BUNDLE 0 0
HELLO 5117 5043
* LABMPE09.13 # sh mpls rsvp-te neighbor
* LABMPE09.14 #
10-23-2015 08:01 AM
HI,
Type (2)
It appears that the neighbor is sending ATM Label range in RESV message. So the local node will ignore and send error message. You may hvae to check why Extreme is sendng C-Type 2 instead of C-Type 1.
12-14-2015 04:33 AM
Hi, Nagendra
Thanks for your answer.
I've opened cases with Cisco and Extreme.
RSVP RESV message contains FLOWSPEC Object class=9 C-Type=2 as described in RFC2215
TOKEN_BUCKET_TSPEC parameter is a part of FLOWSPEC Object.
The XDR description of this parameter is:
struct {
float r;
float b;
float p;
unsigned m;
unsigned M;
} TOKEN_BUCKET_TSPEC;
where [p] means peak traffic rate.
Cisco doesn't accept zero p-value. Default Extreme p-value is zero.
It is possible to change it via Extreme profile configuration
configure mpls rsvp-te profile "rsvp_profile" bandwidth peak-rate *** Kbps
