MPLS TE + CSPF
naive.naive
Got a simple question to ask (no equipment for me to test at the moment) hope it's alright..
Firstly, I know CSPF is enabled by default, is there any cli that can show that ?
Secondly, configured explicit path for the TE, and the 1st hop (hop 0) is directly connected interface, if the IGP (OSPF) goes down, will the tunnel still be up ?
RP/0/RP0/CPU0:CRS#sh mpls traffic-eng tunnels 99
Name: tunnel-te99  Destination: 172.16.1.1
  Status:
    Admin:    up Oper:   up   Path:  valid   Signalling: connected
    path option 10,  type explicit Backup (Basis for Setup, path weight 100)
    G-PID: 0x0800 (derived from egress interface properties)
    Bandwidth Requested: 0 kbps  CT0
    Creation Time: Tue Nov 20 05:09:09 2012 (20w1d ago)
  Config Parameters:
    Bandwidth:        0 kbps (CT0) Priority:  7  7 Affinity: 0x0/0x2
    Metric Type: TE (default)
    Hop-limit: disabled
    AutoRoute:  enabled  LockDown: disabled   Policy class: not set
    Forwarding-Adjacency: disabled
    Loadshare:          0 equal loadshares
    Auto-bw: disabled
    Fast Reroute: Enabled, Protection Desired: Any
    Path Protection: Not Enabled
  History:
    Tunnel has been up for: 20w1d (since Tue Nov 20 05:12:43 ESDT 2012)
    Current LSP:
      Uptime: 20w1d (since Tue Nov 20 05:12:43 ESDT 2012)
    Reopt. LSP:
      Last Failure:
        LSP not signalled, identical to the [CURRENT] LSP
        Date/Time: Wed Feb 22 05:08:17 ESDT 2013 [03:39:36 ago]
Path info (OSPF 10 area 2.0.0.1):
  Hop0: 192.168.1.1
  Hop1: 172.16.1.1
Nikhil Kapoor
HI Navie,
You may want to look at below outputs. This may answer what you are looking for.
Topology
P1 <---------------->P3 ( Running OSPF)
lo 2.2.2.2          lo0 5.5.5.5
Traffic Engineering running between P1 and P3 for simplicity.
P1#show mpls tra tu tun1
Name: P1_t1                               (Tunnel1) Destination: 5.5.5.5
  Status:
    Admin: up         Oper: up     Path: valid       Signalling: connected >>>> Oper status UP
    path option 1, type dynamic (Basis for Setup, path weight 1)
With Dynamic option
P1#sh run int tu 1
Building configuration...
Current configuration : 269 bytes
interface Tunnel1
ip unnumbered Loopback0
load-interval 30
tunnel destination 5.5.5.5
tunnel mode mpls traffic-eng
tunnel mpls traffic-eng priority 7 7
tunnel mpls traffic-eng bandwidth 10
tunnel mpls traffic-eng path-option 1 dynamic
no routing dynamic
end
P1#
P1#show ip ro 5.5.5.5 >>>> Destination
Routing entry for 5.5.5.5/32
  Known via "ospf 100", distance 110, metric 2, type intra area
  Last update from 10.10.10.18 on GigabitEthernet1/0, 00:22:47 ago
  Routing Descriptor Blocks:
  * 10.10.10.18, from 5.5.5.5, 00:22:47 ago, via GigabitEthernet1/0
      Route metric is 2, traffic share count is 1
P1#
I made OSPF IGP between P1 and P3 down.
P1#
*Mar  2 08:24:12.675: %OSPF-5-ADJCHG: Process 100, Nbr 5.5.5.5 on GigabitEthernet1/0 from FULL to DOWN, Neighbor Down: Dead timer expired
P1#
*Mar  2 08:24:26.639: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
P1#show mpls traffic-eng tunnels
  Status:
    Admin: up         Oper: down   Path: not valid   Signalling: Down
  Config Parameters:
    Bandwidth: 10       kbps (Global)  Priority: 7  7   Affinity: 0x0/0xFFFF
    AutoRoute:  disabled  LockDown: disabled  Loadshare: 10       bw-based
    auto-bw: disabled
  History:
    Tunnel:
      Time since created: 10 minutes, 4 seconds
      Time since path change: 1 minutes, 14 seconds
      Number of LSP IDs (Tun_Instances) used: 27
    Prior LSP:
      ID: path option 1 [20]
      Removal Trigger: path error
      Last Error: PCALC:: No path to destination, 5.5.5.5
The same result I would expect for explicit path as well. Hence it looks like if the next hop or IGP adj between 2 routers is down TE tunnel will go down.
Nikhil
Akash Agrawal
Hi Navie,
To your first query to check whether CSPF or PCALC is enabled or not.
There is command "sh mpls traffic-eng topology path tunnel " for manual execution of Path Computation in Cisco IOS. This command will only give output of dynamic path based on PCALC computation.
To your second query:
I am not sure with the IOS-XR behaviour. I checked with IOS and below is my observation.
- Though router knows about next-hop address which is of connected device to reach the tail end, but it should be in TE topology databse also to check constraint specified in the TE tunnel.
- When OSPF is down on a link , router does not include this link into Opaque-area LSA and hence does not advertise Opaque-area LSA for this link to any router.
- This link also does not get added into MPLS traffic-eng database. (based on observation)
- Now when you configure a tunnel with path-option as dynamic, head end router runs CSPF or PCALC to know the shortest path to reach destination meeting all constrains specified and creates an ERO based on which PATH messgaes reached till Tail end router.
- In case of Explicit-path also Head end router runs PCALC to check if links specified in explicit route are meeting all constraints specified in TE tunnel or not. If not it will show an error and will not initiate PATH message.
- So say suppose you have added a link in explicit path which is not there in TE topology, it will give you error like  "Last Error: PCALC:: No addresses to connect 172.31.12.2 to 172.31.23.3"
Topology
R1[.1]-----172.31.12.0/24----[2.]R2[.2]----172.31.23.0/24-----[.3]R3
|-----------------------------172.31.13.0/24--------------------------------------|
tunnel is configured on R1 for R3
R1#  sh runn int tunnel10
Current configuration : 274 bytes
interface Tunnel10
tunnel destination 3.3.3.3
tunnel mpls traffic-eng bandwidth 200
tunnel mpls traffic-eng path-option 1 explicit name R1-R2-R3
end
R1#
R1#sh ip expl name R1-R2-R3
PATH R1-R2-R3 (strict source route, path complete, generation 16)
    1: next-address 172.31.12.2
    2: next-address 172.31.23.3
R1#
CASE-I
OSPF is diabled between R1 and R2 due to password mismatch but R2 can advertises link address via R2-R3-R1 neighborship.
R1#sh mpls traffic tunnel tunnel 10
Name: R1_t10                              (Tunnel10) Destination: 3.3.3.3
  Status:
    path option 1, type explicit R1-R2-R3
  Config Parameters:
    Bandwidth: 200      kbps (Global)  Priority: 7  7   Affinity: 0x0/0xFFFF
    AutoRoute:  disabled  LockDown: disabled  Loadshare: 200      bw-based
    auto-bw: disabled
  Shortest Unconstrained Path Info:
    Path Weight: 10 (TE)
    Explicit Route: 172.31.13.3 3.3.3.3
  History:
    Tunnel:
      Time since created: 1 hours, 51 minutes
      Time since path change: 20 seconds
      Number of LSP IDs (Tun_Instances) used: 268
    Prior LSP:
      ID: path option 1 [264]
      Removal Trigger: path verification failed
      Last Error: PCALC:: Explicit path has unknown address, 172.31.12.2  <<<<<<<<<<<<<<<<<
R1#
CASE-II
OSPF is disabled between R2 and R3 due to password mismatch but R3 can advertises link address via R1-R3 neighborship.
R1#sh mpls traffic-eng tunnels tunnel 10
  Status:
  Config Parameters:
    auto-bw: disabled
  History:
    Tunnel:
      Time since created: 1 hours, 36 minutes
      Time since path change: 33 seconds
      Number of LSP IDs (Tun_Instances) used: 242
    Prior LSP:
      ID: path option 1 [237]
      Last Error: PCALC:: No addresses to connect 172.31.12.2 to 172.31.23.3  <<<<<<<<<<<<<<<<<<
R1#
Opaque-area LSA contains Neighbor Address information as well
LS age: 677
  Options: (No TOS-capability, DC)
  LS Type: Opaque Area Link
  Link State ID: 1.0.0.1
  Opaque Type: 1
  Opaque ID: 1
  Advertising Router: 1.1.1.1
  LS Seq Number: 80000008
  Checksum: 0x5769
  Length: 132
  Fragment number : 1
    Link connected to Point-to-Point network
      Link ID : 3.3.3.3
      Interface Address : 172.31.13.1
      Neighbor Address : 172.31.13.3                    <<<<<<<
      Admin Metric : 10
      Maximum bandwidth : 1250000
      Maximum reservable bandwidth : 937500
      Number of Priority : 8
      Priority 0 : 937500      Priority 1 : 937500
      Priority 2 : 937500      Priority 3 : 937500
      Priority 4 : 937500      Priority 5 : 937500
      Priority 6 : 937500      Priority 7 : 937500
      Affinity Bit : 0x0
      IGP Metric : 10
    Number of Links : 1
good explanation akash.
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
