MPLS TE tunnel not coming up - RSVP issue?
dodgerfan78
I have two routers R2 and R5 back to back and I am trying to create an MPLS TE tunnel between them. R2 already has one tunnel up and running to another router R1.
I think my issue is that no RSVP traffic is being sent by R2 or R5. Here is my interface config on R5 and some show commands:
R5#show run int s2/0
Building configuration...
Current configuration : 143 bytes
interface Serial2/0
ip address 192.168.25.5 255.255.255.0
mpls traffic-eng tunnels
fair-queue 64 256 32
ip rsvp bandwidth 1000 1000
end
R5#show ip int brief s2/0
Serial2/0 192.168.25.5 YES NVRAM up up
R5#show ip rsvp counters in s2/0
Serial2/0 Recv Xmit Recv Xmit
Path 0 0 Resv 0 0
PathError 0 0 ResvError 0 0
PathTear 0 0 ResvTear 0 0
ResvConfirm 0 0 ResvTearConfirm 0 0
UnknownMsg 0 0 Errors 0 0
R5#
I have mpls traffic-eng tunnels on all routers and interfaces. Here here is my tunnel config on R5 towards R2:
R5#show run int tun 2
Current configuration : 174 bytes
interface Tunnel2
ip unnumbered Loopback0
tag-switching ip
tunnel destination 10.0.0.2
tunnel mode mpls traffic-eng
tunnel mpls traffic-eng path-option 1 dynamic
end
I also am learning all addresses via OSPF so R5 does have a route (and can ping) 10.0.0.2 (R2's loopback)
Any ideas where this is failing? Why isn't RSVP sending packets?
17 Replies 17
u can see tunnel1 config that in both configuration two of command r not comming up same
interface Tunnel1
ip unnumbered Loopback9
tunnel destination 192.168.1.5
tunnel mpls traffic-eng autoroute announce
tunnel mpls traffic-eng priority 1 1
tunnel mpls traffic-eng bandwidth 50
tunnel mpls traffic-eng path-option 10 dynamic
>>> tunnel mpls traffic-eng auto-bw frequency 600
no routing dynamic
end
i want to set frequency time 10 min and tunnel max n min bandwidth that should change according to tunnel adjustmen after frequency but these both command not coming up at same time. i have done sumthin wrong?
hello my freind i dont know that much about TE but in ur tunnel interface commands u have nt put auto route announce command---> tunnel mpls traffic-eng autoroute announce
interface Tunnel1
ip unnumbered Loopback1
tunnel destination 192.168.1.3
tunnel mpls traffic-eng autoroute announce <--this command is very important)
tunnel mpls traffic-eng bandwidth 300
cus ur data cant route if it doesnt know the route. might be it can problem--
static
policy base
auto route
removing duplicate post
