MPLS-TE Tunnel problem
anil_chaudhary
I am trying to initate a simple tunnel from GSR12008 to one of the RouterTesting system.
<GSR> ------------- <RouterTester System>
171.60.1.1 171.60.1.2
I have OSPF and RSVP configured on both sides. I can ping 171.60.1.2 but tunnel to 171.60.1.2 doesn't come up. Below is the output of 'show mpls traff tunn' and 'show ip route'. I have also attached the GSR config for reference.
-anil
Show mpls traffic-eng tunnels o/p:
Name: GSR-12008_t171 (Tunnel171) Destination: 171.60.1.2
Status:
Admin: up Oper: down Path: not valid Signalling: Down
path option 1, type dynamic
Config Parameters:
Bandwidth: 100 kbps (Global) Priority: 7 7 Affinity: 0x0/0xFFFF
Metric Type: IGP (global)
AutoRoute: disabled LockDown: disabled Loadshare: 100 bw-based
auto-bw: disabled
History:
Tunnel:
Time since created: 2 hours, 39 minutes
Number of LSP IDs (Tun_Instances) used: 473
Path Option 1:
Last Error: PCALC:: No path to destination, 171.60.1.2
Show ip route o/p:
Gateway of last resort is not set
171.60.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 171.60.1.2/32 is directly connected, POS6/0
C 171.60.1.0/24 is directly connected, POS6/0
117.0.0.0/32 is subnetted, 1 subnets
C 117.117.117.117 is directly connected, Loopback0
169.169.0.0/24 is subnetted, 1 subnets
C 169.169.169.0 is directly connected, FastEthernet0/7
173.6.0.0/24 is subnetted, 1 subnets
C 173.6.1.0 is directly connected, FastEthernet0/6
41.0.0.0/32 is subnetted, 4 subnets
O 41.41.2.2 [110/4] via 171.60.1.2, 00:37:40, POS6/0
O 41.41.1.1 [110/2] via 171.60.1.2, 00:37:40, POS6/0
O 41.41.2.1 [110/3] via 171.60.1.2, 00:37:40, POS6/0
O 41.41.1.2 [110/3] via 171.60.1.2, 00:37:40, POS6/0
146.223.0.0/21 is subnetted, 1 subnets
C 146.223.72.0 is directly connected, Ethernet0
12.0.0.0/24 is subnetted, 5 subnets
O 12.0.12.0 [110/4] via 171.60.1.2, 00:37:40, POS6/0
O 12.0.14.0 [110/2] via 171.60.1.2, 00:37:40, POS6/0
O 12.0.8.0 [110/3] via 171.60.1.2, 00:37:40, POS6/0
O 12.0.10.0 [110/4] via 171.60.1.2, 00:37:40, POS6/0
O 12.0.6.0 [110/3] via 171.60.1.2, 00:37:40, POS6/0-
Harold Ritter
The IP address specified on the "tunnel destination" statement should be the address of the routerid of the tail-end router, not the interface address.
Hope this helps,
Harold Ritter
Hope this helps,
Thanks Hritter. It helped me in solving the problem.
cheers,
-anil
