Remote access to PE question
ellemen
Hi experts, we are building a mpls core. The problem is our PE is facing hundreds CE. The traffic from each CE may contain several applications and I have to separate them to diffenent VRF in PE.
Do you have any good sulotion about that especially for the multiple remote access part.
Thanks.
smahbub
Level 6
Level 6
I guess there should be no problem with such a setup. The PE will be able to differntiate the applications based on the destination and send it across. So even if there are many CE facing the PE the PE will function normally.
