MPLS TE
arun kumar
Can i create two MPLS TE tunnels from PE A to PE B with the same destination address as the loopback of PE B with "autoroute-announce" enabled being two tunnels have different explicit paths created ?
e.g
From PE A:
int lo0
ip address 10.10.10.1 255.255.255.255
int tu1
ip unnumbered loopback 0
tunnel mode mpls traffic-eng
tunnel destination 20.20.20.1
tunnel mpls traffic-eng autoroute-announce
int tu2
PE B:
int lo 0
ip address 20.20.20.1 255.255.255.255
mheusing
Yes you can. And you can even use unequal cost load balancing, if it is desired. You will need a tunnel bandwidth statement and CEF will be distributing the load acording to the reserved bandwidth ratio of the two tunnels. The routing table would contain two pathes to the destination networks routed across the tunnels. To make sure your IGP selects the tunnels as best path you might want to adjust the metric of the tunnels for IGP path selection:
int tu1
tunnel mpls traffic-eng bandwidth 1000
tunnel mpls traffic-eng autoroute metric relative -1
The last command will ensure the tunnel is always slightly better than the physical interfaces towards the destination.
Hope this helps! Please rate all posts.
Regards, Martin
shivlu jain
Level 5
Level 5
with this configuration, if you are having two paths for the same detination then the load balancing will occur. So the best is not to use autoroute announce. Instead of that you can use the tunnel priority. If one goes down second will come up.
regards
shivlu
etienne.basset
hello
you may get different result;
both tunnel can take the same path or take different path.
if your first tunnel doesn't leave enough bandwith on one link for the second tunnel, the second tunnel will find an other path (assuming they have the same priority).
to be sure to take different path, use 'explicit'
regards
etienne
yleteigner
Another way to proceed if you want both tunnels to be on different path without playing with bandwidth, is to use tunnel affinity.
