MPLS Traffic Engineering and OSPF
grichardson661
I'm pretty new to MPLS. A colleague and I and setting up a MPLS LAB in a physical ring topology.
Has anyone any ideas how we suppress an MPLS tunnel from becoming a transit to reach the physical OSPF enabled interfaces (that connect the ring). These interfaces physically connect the ring topology and is the backbone running in Area 0. The Tunnels should not become a transit these physical interfaces as it blocks further MPLS path engineering.
It seems we need to apply some sort of filter (whether's its multi process OSPF, VRF or a MPLS function) to prevent the physical /30 networks from being advertised into the MPLS tunnels.
Any suggestions would be appreciated.
2 Accepted Solutions
Akash Agrawal
A topology and basic network configuration would help to unerstand exact query. If you dont want to transit any tunnel through a particular link and dont want to advertise a particular /30 network into TE topology database, can't we simply disable TE on that link.
Probably i am not getting your query peroperly.
Akash
Harold Ritter
I presume you use the "autoroute announce", which would explain the behavior you are currently using. With "autoroute announce", all ospf routes downstream of the TE tunnel tail end will be reachable via the tunnel interface. You can remove the "autoroute announce" and use a static route with the tunnel interface as the next hop to selectively use the tunnel.
Akash Agrawal
Akash
Harold Ritter
Removing 'autoroute announce' and adding static routes for the tunnels has resolved the issue we were seeing. Cheers guys!
