MPLS VFI forwarding
helipos00
I've set up the following lab. The "customers", most of the purple devices have no problem with connectivity at layer 2 or 3 except R16 and R19.
The problem between S20 and R6/R12, as if I get R12/R6 to switch to their backup xconnect neighbours (Device 3) it works fine, R16 and R19 find the other customers.
Routers 12 and 6 are not capable of manual VFI's thus have been xconnected to S20 with a backup to Device 3.
S20 is a 6500 running ADVENTERPRISEK9 12.2(33)SXI6
Devices 1-3 are ASR 920's
R12 and R6 both 2811 running adventerprisek9-mz.124-15.T9
Any ideas greatly appreciated
R6#show xcon all
Legend: XC ST=Xconnect State, S1=Segment1 State, S2=Segment2 State
UP=Up, DN=Down, AD=Admin Down, IA=Inactive, NH=No Hardware
XC ST  Segment 1                         S1 Segment 2                         S2
UP pri ac   Fa0/1(Ethernet)              UP mpls 1.0.0.21:100                 UP
IA sec ac   Fa0/1(Ethernet)              UP mpls 1.0.0.33:100                 DN
S20#show vfi
Legend: RT=Route-target, S=Split-horizon, Y=Yes, N=No
VFI name: PORTAL, state: up, type: multipoint
  VPN ID: 100
  Local attachment circuits:
    Vlan5
  Neighbors connected via pseudowires:
  Peer Address     VC ID        S
  1.0.0.31         100          Y
  1.0.0.6          100          N
  1.0.0.12         100          N
  1.0.0.11         100          N
  1.0.0.33         100          Y
  1.0.0.32         100          Y
S20#show mpls l2 vc
Local intf     Local circuit              Dest address    VC ID      Status
VFI PORTAL     VFI                        1.0.0.6         100        UP
VFI PORTAL     VFI                        1.0.0.11        100        UP
VFI PORTAL     VFI                        1.0.0.12        100        UP
VFI PORTAL     VFI                        1.0.0.31        100        UP
VFI PORTAL     VFI                        1.0.0.32        100        UP
VFI PORTAL     VFI                        1.0.0.33        100        UP
helipos00
Here is the VFI debug if that might help anyone as I bring the fa1/1 interface on the S20 up.
I've also slightly modified the network to simplify it a little.
When I run the same debug commands on the ASR I get no output.
I thought, I'd fixed it......
I did find
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-0SY/configuration/guide/15_0_sy_swcg/vpls.html
But I tried both a trunk and access port across to S2 from S20 with no luck. As soon as that VFI on S20 comes up devices R15, 16, 19 all drop their connections.
I'm not sure if its a consequence or cause but none of the MPLS L2 VC's leaving S20 have any outgoing packets.
Local interface: VFI PORTAL VFI up
  Interworking type is Ethernet
  Destination address: 1.0.0.31, VC ID: 100, VC status: up
    Output interface: none, imposed label stack {}
    Preferred path: Tunnel31,  active
    Default path: disabled
    No adjacency
  Load Balance: none
  Flow Label: Disabled
  Create time: 00:08:16, last status change time: 00:00:07
  Signaling protocol: LDP, peer 1.0.0.31:0 up
    Targeted Hello: 1.0.0.20(LDP Id) -> 1.0.0.31, LDP is UP
    Status TLV support (local/remote)   : enabled/not supported
      LDP route watch                   : enabled
      Label/status state machine        : established, LruRru
      Last local dataplane   status rcvd: No fault
      Last local SSS circuit status rcvd: No fault
      Last local SSS circuit status sent: No fault
      Last local  LDP TLV    status sent: No fault
      Last remote LDP TLV    status rcvd: Not sent
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local 35, remote 38
    Group ID: local 0, remote 0
    MTU: local 1500, remote 1500
    Remote interface description:
    MAC Withdraw: sent:1, received:0
  Sequencing: receive disabled, send disabled
  Control Word: On (configured: autosense)
  VC statistics:
    transit packet totals: receive 1088, send 0
    transit byte totals:   receive 120240, send 0
    transit packet drops:  receive 0, send 0
