01-02-2012 08:45 PM
Dear All
I am trying to test the use of ORF with extcommunity using "bgp rr-group" to make the PEs not advertise any routes with extcommunity which are not allowed on the RR using " bgp rr-group" command..
I am not sure if I have misinterpreted using "bgp rr-group" for testing ORF at the RR to advertise the list of RTs it wants to receive updates from Route-Reflector-Client PEs..May be there is some other way round for using ORF with extcommunity RT..
I can see on the RR that I am only placing the routes which are permitted under the extcommunity list allowed under "bgp rr-group" config but the PEs are still advertising all the routes and ORF is not working ..Below are my configs
address-family vpnv4
bgp rr-group 10
neighbor mp-ibgp send-community extended
neighbor mp-ibgp route-reflector-client
neighbor mp-ibgp capability orf prefix-list send
neighbor mp-ibgp route-map cus1 in
neighbor 10.0.1.1 activate
neighbor 10.0.6.1 activate
exit-address-family
ip extcommunity-list 10 permit rt 64513:100
route-map cus1 permit 10
match extcommunity 10
I am not sure how can I make the RR advertise the set of RTs it is permitting to the PEs so that they can stop advertising the unwanted routes..
I can see on the PE though for ORF capability received but it says for Prefix-List and not extcommunity
edge1.pop1#show ip bgp vpnv4 all neighbors 10.0.2.1
BGP neighbor is 10.0.2.1, remote AS 64513, internal link
Member of peer-group mp-ibgp for session parameters
BGP version 4, remote router ID 10.0.2.1
BGP state = Established, up for 00:06:10
Last read 00:00:34, last write 00:00:35, hold time is 180, keepalive interval
is 60 seconds
Neighbor sessions:
1 active, is multisession capable
Neighbor capabilities:
Route refresh: advertised and received(new)
Four-octets ASN Capability: advertised and received
Address family VPNv4 Unicast: advertised and received
Multisession Capability: advertised and received
Message statistics, state Established:
InQ depth is 0
OutQ depth is 0
Sent Rcvd
Opens: 1 1
Notifications: 0 0
Updates: 4 5
Keepalives: 7 7
Route Refresh: 0 0
Total: 12 13
Default minimum time between advertisement runs is 0 seconds
For address family: VPNv4 Unicast
Session: 10.0.2.1 session 1
BGP table version 10, neighbor version 10/0
Output queue size : 0
Index 15
Address family not supported notification sent
15 update-group member
mp-ibgp peer-group member
NEXT_HOP is always this router
AF-dependant capabilities:
Outbound Route Filter (ORF) type (128) Prefix-list:
Send-mode: received
Varma
Solved! Go to Solution.
01-03-2012 04:29 AM
Hi Kishore,
ORF for ext communities -and hence RT- was never implemented.
You could look at RT Constrained route distribution. This is filtering outbound from the RRs to the PEs. You do not have to configure "filters" for this feature, it is automatic.
Luc
01-03-2012 01:00 AM
Hi Varma,
The inbound route filtering, i.e. the rr-group and Route-Target ext-comm list, will work.
Outbound filtering, i.e. ORF, is not supported for Route-Targets. ORF is prefix-list based, not RT-based.
Luc
01-03-2012 01:21 AM
Hi Luc
Thanks a lot for the clarification..I was going through various online documentation where it was mentioned that ORF can be used with extcommunity also ..I did try it as mentioned in my first post but it did not work though
In the book "MPLS and VPN Architectures" -Part2:MPLS-based Virtual Private Networks/Chapter 9 & Chapter 12 its mentioned
This solution is provided through use of the ORF capability . Using this capability, each route reflector is preconfigured with a list of route targets that it will accept for reflection to any PE-clients. All the PE-clients are treated as a single peer group, so the ORF capability is used to set the outbound filtering of the PE-client so that it does not send unwanted routes toward the route reflector.
Varma
01-03-2012 03:45 AM
Varma,
In your config you are using the inbound route filtering for the RT's on the RR. so I take it that its working on the RR.
It's only the PE's that are still advertising all the routes right?
Kishore
01-03-2012 03:27 AM
Hi Varma,
I do see you point
As per the link below it says that it ORF supports extended communities. This link is taken from MPLS and VPN Architecutures Vol II
ORF-type | ORF-type Value | Description |
NLRI | 1 | The NLRI ORF-type provides address prefixes based on route filtering. |
Communities | 2 | The Communities ORF-type provides communities-based route filtering. |
Extended Communities | 3 | The Extended Communities ORF-type provides extended community-based route filtering. |
Prefix-list | 129 | The Prefix-list ORF-type provides prefix-list route filtering. |
However, as Luc mentioned I have always seen ORF for prefix-list.In fact even in the IOS there is no provision or option to use anything else other than a prefix-list. Ivan is a distinguished engineer surely there might have been some implementations in the past or something..
Luc, do you think you can please confirm if at any stage the ORF for RT's was ever used. I know you can get the inside story.
Appreciate your help
Kishore
01-03-2012 04:29 AM
Hi Kishore,
Luc
01-03-2012 04:40 AM
Hi Luc
Thanks a lot for clarifying the ORF feature for extcommunity-RT..Yes I did see for the IOS-XE implementation.
Hey Kishore
Nice to see you again Yes that was the problems of PE still advertsing all routes but now it all makes sense after Luc's explaination.
Thanks again to both of you.
Varma
01-03-2012 04:53 AM
Hi Varma,
It is almost a futile attempt to add anything to Luc's and Kishore's answers... just wanted to add that for currently existing ORF types, the IANA is maintaining a ORF type list here:
http://www.iana.org/assignments/bgp-parameters/bgp-parameters.xml#bgp-parameters-9
Currently, the prefix-based ORF has the type number 64. Other are currently unassigned.
Best regards,
Peter
01-03-2012 04:58 AM
Hi Peter
Thanks much for sharing the link
Varma
01-03-2012 11:51 PM
Hi Luc,
Do you konw if it is going to be supported in near future on IOS-XR at least ?
The feature is really good to be used on IOS-XE ( ASR1K as RR and PE ) but can't take full benefit unless other PE like 12K supports this so was curious when can we see in XR ?
Chintan
