MPLS VPN With Cisco CSR and Cisco IOS-XR
sachin30720041
Hello All,
<------Site1-------><-----Site2---------->
R1----R2---R3---R4--XR5--R6---XR7---R8
R1, R2. R3, R4,R6, R7 are cisco CSR.
XR5, XR7 are cisco XR.
R1 and R8 are CE routers.
R2 and XR7 are PE routers.
ospf, ldp is running on r2,r3,r4 in site1.
ospf, ldp is running on xr5,r6,xr7 in site2.
100.100.100.100, 20.20.20.20 are loopbacks on R1(CE router site1) and R8(CE router site2).
192.168.255.2, 192.168.255.7 are loopbacks of R2 and XR7 respectively.
R4 and XR5 are running ipv4 bgp label. and exchange 192.168.255.2(loopback of R2) and 192.168.255.7(loopback of XR7) respectively.
R2 and XR7 are running BGP vpnv4.
Below is the configuration.
R2
vrf definition A
rd 192.168.255.2:65000
address-family ipv4
route-target export 99:99
route-target import 99:99
exit-address-family
interface Loopback1
ip address 192.168.255.2 255.255.255.255
ip ospf 1 area 0
interface gig2
no sh
vrf forwarding A
ip address 192.168.12.2 255.255.255.0
ip ospf 10 area 0
interface gig1
no sh
ip address 192.168.23.2 255.255.255.0
ip ospf 1 area 0
mpls ip
router ospf 10 vrf vrf1
redistribute bgp 65000 subnets
router ospf 1
router bgp 65000
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 192.168.255.7 remote-as 65001
neighbor 192.168.255.7 update-source Loopback1
neighbor 192.168.255.7 ebgp-multihop
address-family ipv4
exit-address-family
address-family vpnv4
neighbor 192.168.255.7 activate
neighbor 192.168.255.7 send-community both
exit-address-family
address-family ipv4 vrf A
redistribute ospf 10
exit-address-family
R4
interface Loopback1
ip address 192.168.255.4 255.255.255.255
ip ospf 1 area 0
interface gig2
no sh
ip address 192.168.34.4 255.255.255.0
ip ospf 1 area 0
mpls ip
interface gig1
no sh
ip address 192.168.45.4 255.255.255.0
mpls bgp forwarding
router ospf 1
redistribute bgp 65000 subnets route-map REDISTRIBUTE_IN_IGP
router bgp 65000
network 192.168.255.2 mask 255.255.255.255
neighbor 192.168.45.5 remote-as 65001
address-family ipv4 unicast
neighbor 192.168.45.5 activate
neighbor 192.168.45.5 send-label
ip prefix-list FOREIGN_PREFIXES seq 10 permit 192.168.255.7/32
route-map REDISTRIBUTE_IN_IGP permit 10
match ip address prefix-list FOREIGN_PREFIXES
R5
interface Loopback1
ipv4 address 192.168.255.5 255.255.255.255
interface GigabitEthernet0/0/0/1
no sh
ipv4 address 192.168.45.5 255.255.255.0
interface GigabitEthernet0/0/0/0
no sh
ipv4 address 192.168.56.5 255.255.255.0
prefix-set FOREIGN_PREFIXES
192.168.255.2/32,
192.168.255.3/32
end-set
route-policy DEFAULT
pass
end-policy
route-policy REDISTRIBUTE_IN_IGP
if destination in FOREIGN_PREFIXES then
pass
endif
end-policy
router static
192.168.45.4/32 GigabitEthernet0/0/0/1
router ospf 1
router-id 192.168.255.5
redistribute bgp 65001 route-policy REDISTRIBUTE_IN_IGP
area 0
interface Loopback1
router bgp 65001
network 192.168.255.7/32
allocate-label all
neighbor 192.168.45.4
remote-as 65000
address-family ipv4 labeled-unicast
route-policy DEFAULT in
route-policy DEFAULT out
mpls ldp
address-family ipv4
R7
route-policy pass
pass
exit
vrf A
import route-target
99:99
export route-target
99:99
interface Loopback1
ipv4 address 192.168.255.7 255.255.255.255
no vrf vrf1
ipv4 address 192.168.67.7 255.255.255.0
no sh
vrf A
ipv4 address 192.168.78.7 255.255.255.0
no sh
router ospf 1
address-family ipv4
area 0
interface Loopback1
vrf A
area 0
int gi0/0/0/0
router bgp 65001
address-family vpnv4 unicast
neighbor 192.168.255.2
remote-as 65000
ebgp-multihop
route-policy pass in
route-policy pass out
vrf A
rd 192.168.255.12:65001
redistribute ospf 1
mpls ldp
address-family ipv4
I see 100.100.100.100/32(R1's loopback) in R8's routing table and 20.20.20.20(R8's loopback) in R1's routing table. Routes between R1 and R8 are getting exchanged. But ping is not working from R1 to R8.  XR7 has the following labels.
RP/0/RP0/CPU0:XR7 # show mpls forwarding
incoming.   outgoing.    Prefix.                         interface.      nexthop
label            label
24002         Pop            192.168.255.2/32    Gi0/0/0/1    192.168.67.6
For prefix 192.168.255.2(R2's loopback),  XR7 is poping the label.
On R2 I see label 19 as an outgoing label for 192.168.255.7(XR7's loopback).
R2#show mpls forwarding-table
20   19    192.168.255.7/32 0     Gi1   192.168.23.3
That's why the ping request from R1 reaches R8 but the reply is dropped by XR7.
Do I need to do extra configuration on XR7?
Sachin
Harold Ritter
Hi @sachin30720041 ,
The issue is that when you configure an ebgp session, XR does not allow the session to be established over an LSP by default. It does that by installing a pop label operation locally for the neighbor address. You can change that default behavior by adding the mpls keyword to the "ebgp-multihop" command as follow:
XR7:
router bgp 65001
remote-as 65000
ebgp-multihop mpls
This should fix the issue you are seeing.
Harold Ritter
XR7:
router bgp 65001
remote-as 65000
ebgp-multihop mpls
Thank you so much, Harold!!!
