MPLS VPNs - Latency
Mikey John
Hello All,
I have a MPLS VPN setup for one of my sites. We have a 10M pipe (Ethernet handoff) from the MPLS SP, and it is divided into 3 VRFs.
6M - Corp traffic
2M - VRF1
2M - VRF2
The users are facing lot of slowness while trying to access application on VRF1. I can see the utilization on the VRF1 is almost 60% of it's total capacity (2M). Yesterday when trying to ping across to the VRF1 Peer in the MPLS cloud, I was getting a Max response time of 930ms.
xxxxx#sh int FastEthernet0/3/0.1221
FastEthernet0/3/0.1221 is up, line protocol is up
  Hardware is FastEthernet, address is 503d.e531.f9ed (bia 503d.e531.f9ed)
  Description: xxxxx
  Internet address is x.x.x.x/30
  MTU 1500 bytes, BW 2000 Kbit, DLY 1000 usec,
     reliability 255/255, txload 71/255, rxload 151/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1221.
I also see a lot of Output drops on the physical interface Fa0/3/0. Before going to the service provider, can you please tell me if this can be an issue with the way QoS is configured on these VRFs?
xxxxxxx#sh int FastEthernet0/3/0 | inc drops
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3665
Appreciate your help.
Mikey
Hi Mikey,
1) Will output drops also contribute to the latency here?
Yes, output drops do cause packet loss hence re-transmits causing latency etc.
2) I can try and enable IP accounting on that sub-interface (VRF) and see the load. Thoughts?
IP accounting helps you know which host is causing the overload or offending  the link etc.
I would defintely recommend graphing the interfaces and it would give you a good idea.
3) As you said, if the 2M gets maxed out I would see latency as the shaper is getting fully utilized. But I don't see that on the interface load as mentioned above? I have pasted the ping response during the time load output was taken. I can;t read much into the policy map output, but does it talk anything about 2M being fully utilized and hence packets getting dropped.
The packets dont get dropped but queued thats why shapers are good.  policers on the other hand drop packets.
shapers just queue them (buffer) and caust latency but not drop them as that would cause TCP re-transmits.
Kishore
rate if helps and mark correct if answered
15 Replies 15
Mikey John
Appreciate if someone replies on this.
Mikey
Mikey,
It is possible that these issues can be caused by your QoS policy. Can you show us the configuration of the Fa0/3/0.1221 and Fa0/3/0 interfaces?
Also please try to visit the following document for more information:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml#topic4
Best regards,
Peter
Hi Peter,
The interface and Policy map configs are mentioned below.
interface FastEthernet0/3/0
description xxxx
bandwidth 10000
no ip address
ip flow ingress
ip flow egress
duplex full
speed 10
end
interface FastEthernet0/3/0.1221
description VRF1
bandwidth 2000
encapsulation dot1Q 1221
ip vrf forwarding XYZ
ip address x.x.x.x 255.255.255.252
ip accounting output-packets
ip flow ingress
ip flow egress
service-policy output ABC
end
policy-map ABC
class class-default
  shape average 2000000
Mikey
Hello Mikey,
I apologize for being late here. Can you please post the output of show policy-map interface fa0/3/0.1221 command? Thank you!
Best regards,
Peter
Thanks Peter. The output is shown below.
xxxxxxx#sh policy-map interface fa0/3/0.1221
  Service-policy output: ABC
    Class-map: class-default (match-any)
      27517 packets, 9676419 bytes
      5 minute offered rate 6000 bps, drop rate 0 bps
      Match: any
      Traffic Shaping
           Target/Average   Byte   Sustain   Excess    Interval  Increment
             Rate           Limit  bits/int  bits/int  (ms)      (bytes)
          2000000/2000000   12500  50000     50000     25        6250
        Adapt  Queue     Packets   Bytes     Packets   Bytes     Shaping
        Active Depth                         Delayed   Delayed   Active
        -      0         27517     9676419   238       321248    no
Mikey
Hello Mikey,
Hmm, these statistics are completely correct - no huge drops, no huge amounts of delayed packets. It seems as if this shaper did not have much to do.
Can you post the complete output of the show interface Fa0/3/0? I am interested in seeing all the counters. Is there any other traffic (via a different subinterface) flowing through this physical interface?
Best regards,
Peter
Hi Peter,
I see a lot of Output drops on the physical Interface as per the output below. There is no other traffic flowing through fa0/3/0.1221 as it is in a different VRF.
xxx#sh int fa0/3/0
FastEthernet0/3/0 is up, line protocol is up
  Description: xxxxxxxxx
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
     reliability 255/255, txload 61/255, rxload 93/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full-duplex, 10Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 01:34:32
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3392
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 3674000 bits/sec, 694 packets/sec
  5 minute output rate 2412000 bits/sec, 1099 packets/sec
     4522320 packets input, 3245065176 bytes
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     6621868 packets output, 1830822500 bytes, 0 underruns
     0 lost carrier, 0 no carrier
Mikey
Hi Mikey,
Do you graph the bandwidith in a NMS or something. The rate in your last output shows that its pushing about 2.4Mbps for the entire interface, However, this is a 5minutes average. There could be occasional spikes where the bandwidth almost went above the total speed which is 10M in your case.
Also, another thing. you have mentioned the speed to be 10M on the parent interface. However your entire bandwidth from the SP is 10M as well. Normally you would have the physical interface do a bit more. Is it possible for you to change the physical interface speed to 100M. I am sure it wont affect anything. Just want to see if the output interface drops disappear( I am sure it will )
I guess you are pumping  more over all and the individual vrf's are getting congested as you could see from the bytes delayed. Bytes delayed indicate congestion on the interface. Try monitoring the overall BW transmitted by graphing the traffic and that will give u a good indication.
Hope this gives some insight.
Kishore
Hi Kishore,
Right now the graphing for these interfaces is disabled, so Iam unable to pull out any data. But, on the physical interface the utilization does not go beyond 60% normally.
We have 3 VRFs defined here. All the normal user traffic for accessing corporate apps goes through one VRF, and rest two are for accessing apps over DMZ and other stuff.
VRF1 - 6M
VRF2- 2M ---> where the latency is
VRF 3 - 2M.
These VRFs have been assigned individual BW from the SP end. I fail to understand how utilization overall can affect when specific sub-interface (VRF)? Please elaborate.
The speed 10 setting was given to us by the SP, and Iam not sure if changing that would bring the link down?
Mikey
Hi Mikey,
So the output drops you are seeing is a result of the data pushed via that interface>the speed of the interface. So, when you change the interface speed to > 10 i.e 100Mbps you wil see tat these would disappear.
"The speed 10 setting was given to us by the SP, and Iam not sure if changing that would bring the link down?"
well changing the speed might bring the link down if their side is hard coded or maybe you want to try auto neg to see what they have configured. Anyway in short  I wanted to point out the cause of the output drops.
"These VRFs have been assigned individual BW from the SP end. I fail to understand how utilization overall can affect when specific sub-interface (VRF)? Please elaborate"
What I meant was if all the VRF's were pumping data to their max then you would see that the packets get delayed. When the respective shapers gets full it starts to enqueue packets and hence the slowness or latency.
If only one sub-int is getting maxed out then its purely because the 2M is being fully used and has maxed out. Doesnt matter if others sub-interfaces are sending traffic or not.  you have configured the shaper for 2M and you have fully utilised it.
does this make sense?
Please feel free to ask more.
Kishore
Hi Kishore,
Thanks for the clarification. Let me speak to the service provider and see if we can sort out the Output drops issue.
I had a few more queries.
2) The show int fa0/3/0.1221 output below only shows the load on the physical interface (fa0/3/0) and not of that particuar interface.Right?
xxxxxx#sh int fa0/3/0.1221 | inc load
     reliability 255/255, txload 49/255, rxload 94/255
xxxxx#sh int fa0/3/0 | inc load
xxxxxxx#ping vrf ABC x.x.x.x re 1000
Sending 1000, 100-byte ICMP Echos to x.x.x.x, timeout is 2 seconds:
Success rate is 99 percent (997/1000), round-trip min/avg/max = 12/216/1972 ms
      114998 packets, 36909265 bytes
      5 minute offered rate 11000 bps, drop rate 0 bps
      Match: any
      Traffic Shaping
        -      0         114998    36909265  1667      2329112   no
Mikey
Hi Mikey,
Kishore
Thanks for your inputs Kishore. Pretty helpful.
I had raised a ticket with the SP, and they came back saying that latency/Packet drops is due to high utilization.
I had enabled graphing on the VRF1, and could see that the utilization has not crossed more than 1.2M (out of the 2M alloted). But during those times, when I ping across the VRF peer in the MPLS cloud, I still get a latency of about 800ms. Why is that so? LInk issue?
From the graph, I noticed that the utilization on other VRF2 (6M) primarily used for corporate/Internet traffic is about 85-90%. Can this heavy utilization on VRF2 affect VRF1 (since they are part of the same physical interface Fa0/3/0) and have a total pipe of 10M from SP.
Or can it be a link issue?
Appreciate your inputs again.
MIkey
Can anyone help me with the query in the post above?
Mikey
