Multi-VRF CE
sadao-shibata
Community Member
I just wanted to know if it is possible to implement a Multi-VRF CE with the ff platforms:
SITE-A
Multi-VRF CE (C2811) using VWIC-1-MFT-G703
SITE-B
P.E. (C7206VXR) using PA-MC-8TE1
The two sites above(SITE-A to SITE-B)are linked via E1 connection.
I would appreciate it very much if someone can help me if this configuration is doable. Thanks to you...
Best regards,
GSM
It shouldn't be a problem as both of these platforms support multi-vrf (aka vrf-lite).
Hope this helps,
hi,
could you further confirm what type of encapsulation we should use on the serial sub-interfaces since we can not use an ATM between these two sites?
our plan is to configure two VRFs (VPN-A and VPN-B) bet the two routers (PE and Multi-VRF CE). so, we will create two sub-interfaces? please confirm.
thanks in advance.
Since both the platforms support VRF lite and MPLS VPN, you can use Frame-Relay as the encapsulation for sub interfaces with local DLCI switching.
As the VRF configuration is not media dependent.
HTH-Cheers,
Swaroop
Router 1
interface Serial0/0
no ip address
encapsulation frame-relay
no keepalive
!--- This command disables LMI processing.
interface Serial0/0.1 point-to-point
!--- A point-to-point subinterface has been created.
ip address 172.16.120.105 255.255.255.0
ip vrf forwarding xxx
frame-relay interface-dlci 101
!--- DLCI 101 has been assigned to this interface
Router 2
interface Serial0/0
no ip address
no keepalive
ip address 172.16.120.120 255.255.255.0
hey guys,
thanks for your help. i really appreciate it. i will try this as per your recommendation.
best regards,
