Multi-VRF support on Catalyst IOS Hybrid
ngss
I have Catalyst 6509/Sup720. I intend to use hybrid sw (CatOS [SP] + IOS [RP]).
I am planning to configure Multi-VRF feature.
Is the Multi-VRF feature on hybrid version.? If no, is there a plan to support it in the future.
I saw this feature supported on Cat IOS system native, but can't seem to find on the hybrid one.
SSng
Harold Ritter
Multi-VRF (VRF-Lite) is not supported in Hybrid mode. I don't think that there are any plans to support it in the future either. You would have to migrate to Native mode.
Hope this helps,
Thanks for your response.
SSng
