Multicast for Hub and Spoke VPN
chintan-shah
Level 3
Level 3
Can we have Multicast VPN ( draft-rosen ) for Hub and Spoke based VPN ?
As of now we can not configure two VRF with same MDT Default and MDT Data MDT Multicast Group , which is required for HUB and SPOKE topology speically when I have both HUB  and SPOKE Site on same PE.
Is there any alternate solution ?
Chintan
Hi Chintan
No default mdt won't be needed for HUB_Egress VRF..Multicast Traffic would flow via HUB_Ingress VRF.
Sample output for above topology :-)
224.1.1.1 at SPoke1; 224.2.2.2 at Spoke2; 224.3.3.3 at Spoke3 and 224.4.4 at Hub_CE..everything works fine
Spoke3#mtrace 172.16.51.1 172.16.251.1 224.1.1.1
Mtrace from 172.16.51.1 to 172.16.251.1 via group 224.1.1.1
From source (?) to destination (?)
Querying full reverse path...
0  172.16.251.1
-1  172.16.251.1 PIM  [172.16.51.1/32]
-2  0.0.0.0 None Prune sent upstream !RPF!172.16.2.9 [default]
-3  0.0.0.0 PIM Prune sent upstream [default]
-4  172.16.1.2 PIM Reached RP/Core [172.16.51.1/32]
Spoke3#mtrace 172.16.151.1 172.16.251.1 224.1.1.1
Mtrace from 172.16.151.1 to 172.16.251.1 via group 224.1.1.1
0  172.16.251.1
-1  172.16.251.1 PIM  [172.16.151.1/32]
-3  0.0.0.0 PIM Prune sent upstream [172.16.151.1/32]
-4  172.16.1.2 PIM Reached RP/Core [172.16.151.1/32]
Spoke3#ping 224.1.1.1 source lo0
Sending 1, 100-byte ICMP Echos to 224.1.1.1, timeout is 2 seconds:
Packet sent with a source address of 172.16.251.1
Reply to request 0 from 172.16.2.2, 716 ms
Reply to request 0 from 172.16.2.2, 796 ms
Spoke3#ping 224.2.2.2 source lo0
Sending 1, 100-byte ICMP Echos to 224.2.2.2, timeout is 2 seconds:
Reply to request 0 from 172.16.2.6, 788 ms
Reply to request 0 from 172.16.2.6, 952 ms
Spoke3#
Varma
15 Replies 15
Mohamed Sobair
Level 7
Level 7
Hi Chintan,
Its indeed not supported to have two VRFs with the Same MDT-Default and Data for Multicast VPN.
Do you mean you need to control the Multicast traffic from the HUB and Which Spoke can recieve it? Do you intent to have Fully meshed Multicast between your HUB and Spokes? May you elaborate more on  your exact requirement?
Mohamed
Hi Chintan
Yes we can MVPN for Hun and Spoke VPNs whereby we are using 2 logical peerings with the HUB_CE ie one for Ingress_Routes from Spoks and other for Egress_Routes to Spokes. Here we will have separate MDTs for the 2 Ingress/Egress VRFs and still the Spokes can communicate to each other via the Hub-CE on the Multicast layer without any issues. The Ingress_MDT would be used to send the multicast routes to the Hub_CE and the Egress_MDT would be used to advertise those multicast routes back to the Spoke PEs.
For the Spoke which could be colocated on the same PE as the HUB_CE the multicast communication would still work fine.
Varma
Hi Varma,
Thanks for your response. Can I ask you favor with sample diagram +configuration example to have better understanding ?
Many thanks,
Chintan
Hi Chintan
Lets take below setup
                                       -----------------------Spoke_PE1---------Spoke2_CE
Hub_CE               Hub_PE
            --------------- !          -----------------------Spoke_PE2---------Spoke3_CE
                     Spoke1_CE
Now on HUB_PE we create two VRFs HUB_Ingress and HUB_Egress respectively
ip vrf HUB_Egress
rd 64513:2
route-target export 64513:100
mdt default 239.2.2.2
ip vrf HUB_Ingress
rd 64513:1
route-target import 64513:200
route-target import 64513:300
mdt default 239.1.1.1
Now we bind the respective VRFs to the HUB_CE L3 Links for Ingress(from spoke) and Egress(to spoke) routes
interface FastEthernet3/0
description HUB_Ingress
ip vrf forwarding HUB_Ingress
ip address 172.16.1.1 255.255.255.252
ip pim sparse-dense-mode
duplex auto
speed auto
interface FastEthernet3/1
description HUB_Egress
ip vrf forwarding HUB_Egress
ip address 172.16.1.5 255.255.255.252
duplex auto
speed auto
The Local Spoke1 is also kept as part of Hub_Egress VRF
interface FastEthernet4/0
description SPOKE1
ip address 172.16.2.1 255.255.255.252
duplex auto
speed auto
EBGP is ised as the PE-CE ROuting Protocol..HUB_CE is made Auto-RP for CE-Domain
address-family ipv4 vrf HUB_Ingress
redistribute connected
neighbor 172.16.1.2 remote-as 64514
neighbor 172.16.1.2 activate
neighbor 172.16.1.2 soft-reconfiguration inbound
no synchronization
exit-address-family
address-family ipv4 vrf HUB_Egress
neighbor 172.16.1.6 remote-as 64514
neighbor 172.16.1.6 activate
neighbor 172.16.1.6 allowas-in 5
neighbor 172.16.1.6 soft-reconfiguration inbound
neighbor 172.16.2.2 remote-as 64515
neighbor 172.16.2.2 activate
neighbor 172.16.2.2 soft-reconfiguration inbound
no synchronization
exit-address-family
Spoke2 and Spoke4 VRFs are configured as
SPOKE2
ip vrf SPOKE2
rd 64513:3
route-target export 64513:200
route-target import 64513:100
SPOKE3
ip vrf SPOKE3
rd 64513:4
route-target export 64513:300
This config would achieve us the required Hub and Spoke Topology for Unicast as well as Multicast VPN Traffic.
Varma
Hi Varma,
Thanks for very quick response , I really appreciate it.
Do we really need to configure HUB_Ingress VRF with default MDT ( 239.2.2.2) ?
Because MDT between PE over core is through 239.1.1.1 , so that PIM Join from spokes will be over this MDT ( i.e. come on VRF HUB_Ingress unlike unicast which will be on HUB_egress ) and same time from Hub CPE traffic will go over same MDT.
Multicast between Hub and spoke sites with in PE will be any way part of now same VRF(routing table)so that should be now fine. Right ?
Chintan
Oops, my question was : Do we really need to configure Multicast MDT ( in this case 239.1.1.1) on HUB_Egress VRF ? ☺
Chintan
Hi Chintan
0  172.16.251.1
0  172.16.251.1
Spoke3#
Varma
Perfect – Many thanks.
Chintan
Hi Vaibhava,
I see one caveat for spoke sites on same PE where Primary Hub site configured but Hub is Multihomed to two PE.
In case primary Hub site fails, there is an issue for multicast/unicast for from backup Hub site (PE) for spoke sites which were on primary PE because those spoke sites are part of VRF which only does RT export hence no remote routes for unicast and no mdt default for multicast.
Chintan
Hi Chintan
If such is the case then we can use an additional different RT say 64513:500 for HUB_Egress VRF also which will be only exported imported between the 2 PEs terminating the HUB_CE for proividng reachability to Co-located Spoke.
Varma
Hi Varma,
So you also suggest to configure different MDT on HUB_Egress VRF between 2 PE terminating HUB_CE so that it also take cares of multicast across PE for collocated spokes. Right ?
Chintan
Hi CHintan
Yes we would need different MDT e.g 239.2.2.2 on HUB_Egress_VRF for making the multicast communication up between the co-located Spoke on HUB_PE1 to the backup link on HUB_PE2 connecting to HUB_CE otherwise we would loose multicast traffic between the co-located spoke on HUB_PE1 to the HUB_CE in case of primary link failure.
Varma
Hi Varma,
Thanks for confirmation ☺
Chintan
Hi Mohamed,
The customer ask Hub and spoke L3 MPLS VPN. At the same time, customer also require Multicast over VPN.
I can configure normal Hub and spoke based MPLS VPN to support unicast traffic.
I can also configure multicast default and data mdt in customer VRF on each PE although it will form PIM across all PE ( i.e. Mesh). No issue so far at least to have Multicast working.
Correct me, If I am wrong till this part.
Now, I have situation where on same PE I will have Hub and some of spoke sites ( this is not avoidable all time due to various reasons like last mile , same city etc ), So I will have one VRF for Hub and another VRF for all spoke sites for Hub and spoke requirements. How do I switch Multicast ( PIM Join for RP etc) from one VRF(hub)to another VRF (Spoke) ? I even can’t configure same mdt default and data MDT in both VRF since they are on same PE. This is a problem and I am not sure if today we have any solution with draft-rosen based mVPN.
Hope I am able to make requirement more clear , let me know if you still have any further question.
Thanks in advance for help,
Chintan
